Removed brake booster now pedal is hard?
Old 06-13-2011, 06:17 PM
Cosmos's Avatar
Default Removed brake booster now pedal is hard?
I had to removed my brake booster so I could change my clutch master. I put everything back together but now brake pedal is hard and the car takes real effort to slow down. How can I fix this and how did it happen?
Old 06-13-2011, 06:19 PM
-M-
-M-'s Avatar
was the brake master still attached when you pulled it off?
Old 06-13-2011, 06:40 PM
pewter2002's Avatar
Check the vacuum line is not pinched/split or may have come off entirely. Without the vac assist the pedal will be very hard and the car will be difficult to stop.
Old 06-14-2011, 05:57 AM
Cosmos's Avatar
I totally forgot to plug that back in. Thanks for the reminder!
Quick Reply: Removed brake booster now pedal is hard?
