Carbureted LSX forum - CARBED LS C3 at the Track
holley505
06-13-2011, 08:46 PM
Well... had some issues all day with 3rd gear. I could never make a full pass. Around 900-1000 ft mark I would hit rev limiter or have to let off because my th400 will not shift into high gear under full throttle. I thought it was because I was about a quart low on tranny fluid now I think it maybe vacuum related.
http://www.youtube.com/watch?v=v6WvkGWjXkY
holley505
06-13-2011, 08:47 PM
LOL... listen to the guy on the speaker. Funny stuff.
http://www.youtube.com/watch?v=hf9Icdc5Llw
ZONES89RS
06-13-2011, 10:36 PM
Damn, knockin on 10s!
Great work man, too bad the trans is being lazy, i am sure my TH400 will have no issues when the 6.0 goes in the TA.
94mustang
06-14-2011, 09:09 AM
shift it manually
Doug G
06-14-2011, 05:34 PM
Nice pass' :nod:
Kwikcad500
06-15-2011, 07:37 AM
Very nice! Congrats. How about more details on the combo
team39763
06-15-2011, 09:59 AM
Nice to see you back at it man.
holley505
06-21-2011, 08:21 PM
Tranny I believe has a vacuum issue. I was a qt low that day at the track. But for some reason under FULL WIDE open throttle it will not shift. Shifts good into 3rd at normal and part throttle. My Buddy who is a Master tech thinks we are loosing vacuum at the upper RPMs thus we are going to change the vacuum line to a small size. That should fix the problem.
Those runs I was bumping the rev limiter at about 900-1000ft mark. And the run with the Cobra I let off.
I should be getting about 122-124 mph... guessing 10.8-10.7
LSJM1
06-22-2011, 04:37 AM
There is no vacuum at WOT modulator is only for part throttle shifts
car looks great
holley505
06-22-2011, 02:18 PM
car looks great
then what do you think the issue is?
holley505
07-07-2011, 04:58 PM
Well.. .I was going to run some 1/8th mile...but looks like rain all weekend!
82cetuner
07-07-2011, 05:28 PM
i dont know much about the old trannys but dosnt that one have a tv cable? maybe it needs some adjustment.
82cetuner
07-07-2011, 05:32 PM
btw I love c3 ls cars I had a blast with my 82 that I swapped a ls1 in, only thing i wished it had was a little more power but i still kept up with new vettes with 340hp to the wheels
holley505
07-10-2011, 01:01 PM
NO TV cable... its vacuum and has a modulator. it shift fine in part and normal driving. Difficult to test it on the street. I need to go back to the track... Not a good Idea to test a 10 second street car to see if you can get I high gear at WOT on a public road.
The stunningman
07-10-2011, 02:53 PM
IMHO its most likely a governor issue.
edit: Did a little search that may be relevent:
http://forums.corvetteforum.com/c3-tech-performance/2271745-79-vette-th400-wot-shift-issues.html
P.S. There's always a manual valve body. :)
holley505
07-10-2011, 04:02 PM
thanks good info...
Mr.Nitrous
07-11-2011, 05:15 PM
Good thing I wasn't driving the cobra lol. That was the owners 3rd and 4th pass' in that car. But the vette looks good none the less.
GNCLONE
07-11-2011, 06:49 PM
yes, MORE DETAILS please! I plan on being at Bithlo soon.
holley505
07-12-2011, 08:03 AM
Thx:nod:
That cobra was slow out the gate... and I hit the limiter 2 times at the top of the track in second gear. MAN if I had a third gear I know I would have gone 10.7-10.8 but he still would have caught me... not sure I have a 10.6 in this ride...
BUT THATS MOVING for...
3000lbs C3 with Th400 - 3.36 gear 3500 stall and LSx motor with a 240/246 cam
GNCLONE
07-12-2011, 10:41 AM
Heads? IRS rear? I guess you've tuned it with O2 sensors?
How'd you get a 70s Vette down to 3,000 lbs? I thought they were closer to 3600 - 3700.
speedtigger
07-12-2011, 11:42 AM
I always had a soft sport for the 82 Anniversary. Very classy looking car.
holley505
07-12-2011, 01:13 PM
IRS factory rear with DRAGVETTE.com 4-link suspension... Catherdel heads stock rockers...no O2...
weight was mostly the LS motor and pulling all A/C stuff a few bumper supports, front sway bar... etc. it weighed 3050 without me on Bithlo scale.
OH wicked CARB and tuning over at BOWTIE AUTO in longwood.
GNCLONE
07-13-2011, 04:44 PM
I was going to be happy with my 6.0 combo running 12s!!!!
I guess I need to revise my expectations - 11.99?
Mr.Nitrous
07-13-2011, 05:27 PM
My LS power stang runs in the nines on motor !!!
holley505
07-13-2011, 05:54 PM
My first combo went 12.3-12.0 stall and cam makes a difference
holley505
07-13-2011, 05:55 PM
Nice... I bet it weighs 2700 lbs also with a 4.10 gear and at least 4000 stall
Mr.Nitrous
07-13-2011, 08:16 PM
3100 #'s yes it's got a 4.10 and smaller stall 3600. Btw it runs 8.90's on pump gas and a 150 shot..
holley505
07-15-2011, 04:44 PM
sweet baby jesus... 8.90 on 150 shot. car is working. :D
TXoldskool
07-22-2011, 09:48 PM
More on your LSx....what motor is it? 5.3? 5.7? 6.0? 6.2?
Compression? Intake choice? carb size? header size?
Thanks!
holley505
07-23-2011, 07:49 AM
LS3 2008 block 4 inch stroke... about 11 to 1, 1-1/34 headers, Vic Jr Intake, 780 AED HOLLEY DP
brngrhd
08-04-2011, 10:04 AM
my 69 vette went 6.71@105 in the 1/8 with 3.25 gears 28 inch tall tires 229 236 cam and 10:1 compression with a 468 and was 3000lbs with out me.
brngrhd
08-04-2011, 10:08 AM
so whats that a 414? man thats what i was thinking about doing with my 70nova but thought it would be faster......
melsie68
08-04-2011, 10:24 AM
That setup should be at least in the 10.50 or better range if the LS3 heads are all they are cracked up to be. For your car, I would go to a 4.10 gear, 4500 stall, 1-7/8 headers and get the carb worked by someone who knows what they are doing such as Prosystems.
I hope your transmission issue is as simple as it sounds.
FWIW, my Camaro in the signature is heavier, had much smaller heads and less cam. You should be all over me if you are set up correctly. What kind of 60-foot times did you pull? 1/8 mile times?
holley505
12-10-2011, 11:38 AM
My car was Hit... heading to the track a few months back. SUCKED!! rear passenger side.
Just got it out of the body shop... the week before I has hit I made a few 1/8th miles runs. from 7.1 - 6.9 only difference was the launch and how much heat in the tires!
NEW BEST - nothing changed just heated tires more.
60ft 1.65
1/8th ET 6.94
MPH 100.2
Keep in mind I have a 29 inch tall tire with 3.36 gears. And small LS1 205 AFR heads (NOT THE LS3 Heads) also... I dont have 3rd gear at WOT for 1/4 mile... so thats running to the top of 2nd and letting out or bumping rev limiter. NO ROLL BAR either.
Car has 10.8-10.7 in it the way it is...
with LS3 heads... 4000 stall... 3.73 gears I should be good for 10.2-10.0 1/4 or 6.5-6.4 1/8
I am going to get back to the track...but need to get my brake bled. Soft pedal from sitting for 3 months in the body shop
holley505
12-10-2011, 11:43 AM
http://i243.photobucket.com/albums/ff79/holley505/IMG_0033.jpg
http://i243.photobucket.com/albums/ff79/holley505/IMG_0028.jpg
http://i243.photobucket.com/albums/ff79/holley505/vetteremixrear.jpg
http://i243.photobucket.com/albums/ff79/holley505/vetteremixoutofbooth.jpg
http://i243.photobucket.com/albums/ff79/holley505/vetteremixhoodpainted.jpg
http://i243.photobucket.com/albums/ff79/holley505/vetteremix.jpg
holley505
12-10-2011, 11:59 AM
Pass against a modded Grand sport with drag radials.
http://i243.photobucket.com/albums/ff79/holley505/th_MVI_0026.jpg (http://s243.photobucket.com/albums/ff79/holley505/?action=view¤t=MVI_0026.mp4)
Doug G
12-10-2011, 05:43 PM
Ouch... know the feeling of someone busting up your $hit :bomb:
Glad you're back up and running :cheers:
I was coming home from the track a few years ago when this @ss crossed the double yellow line, went down the side of my truck, up on the borrowed trailer, and caved in the side of my Camaro... RedЯum (http://s10.photobucket.com/albums/a130/Dougs68Camaro/accident/) <-- Pics
http://i10.photobucket.com/albums/a130/Dougs68Camaro/accident/th_DSCF0016.jpg http://i10.photobucket.com/albums/a130/Dougs68Camaro/accident/th_DSCF0014-3.jpg http://i10.photobucket.com/albums/a130/Dougs68Camaro/accident/th_DSCF0004.jpg
holley505
12-12-2011, 10:24 AM
OUCH SUX... but car looks good now! Nice ride!
