best brakes for a 17" Rim for the price?
Old 06-14-2011, 02:00 AM
racerfox's Avatar
Default best brakes for a 17" Rim for the price?
What is the best track/street brake kit for the front for a 17' wheel
i have looked at BAER WILLWOOD AND BREMBO
but i only have about 1500 at most to spend so some ones personal experience would be help full
Old 06-14-2011, 06:21 AM
cookba's Avatar
Brembo Blanks or Napa blanks and Hawk HP or HPS pads and good brake fluid. DONE
Old 06-14-2011, 05:58 PM
SVThuh's Avatar
Wilwoods are probably the best bang for the buck.. At least for their SL*R kits.. I have their SL4R kit and it is pretty awesome bit of kit for the money.
Old 06-14-2011, 06:31 PM
crainholio's Avatar
C5 or C6 front brakes give you a bigger diameter rotor, which improves braking significantly. Just need the calipers and brackets from the donor car and a set of adapters. Do a search on c5 brake and see what you think. Less than $1K usually.
Old 06-14-2011, 11:20 PM
racerfox's Avatar
i agree with the bigger rotor but c5 to ls1 caliper is no difference there clamp pressure/bite is the same i want to move to a minimum 4 piston caliper
do you have a part number that you used for the willwood kit?
Old 06-15-2011, 11:18 AM
rabbit320's Avatar
i duno, ive felt a huge difference between my old c5 and my trans am, c5 really grabs the brakes...
Old 06-15-2011, 11:59 AM
Turnin20s's Avatar
Probably noticed the difference of the pads. I have seen a few tests done where the LS1 brake setup has been within 5 feet stopping difference of the C5 setup. That's on the same car, same brand of pads, similar weather.
On another note there are a few guys that have been using the 2010 Camaro SS calipers and 14" rotors, but 18" wheels.
Old 06-15-2011, 05:21 PM
SVThuh's Avatar
Im running a the 12.2" setup on my car. It came from a buddy that races in CMC2 and they are limited to nothing larger than a 12.2" rotor.
My kit number is #140-10691
The 13" kit is #140-7190 (technically a 12.88" rotor, but the offers a much better caliper than the 13.06" kit which is #140-9833)
PM me if you want more info.. I also have a connection for Wilwood if your interested.
All that being said, I track my car quite frequently and the 12.2" kit is more than sufficient with good pads, both on and off the track.
Old 06-15-2011, 09:34 PM
FASTFATBOY's Avatar
M C6 brakes with ducts and Ferodo DS 2500 pads are light years ahead of the stockers. They can go 30 minute HPDE sessions in a 3800lb Z28 with no problems.
Old 06-15-2011, 10:40 PM
racerfox's Avatar
sent you a pm
Quick Reply: best brakes for a 17" Rim for the price?
