Misfire help. need help interpreting HP tuners logs files
Old 06-14-2011, 10:07 AM
UMD_Jesse's Avatar
Location: Fairfax County, VA (You know you're here when you see the bad roads)
Default Misfire help. need help interpreting HP tuners logs files
Ok,
Pulled into a gas station, everything, fine, pulled out one day and engine runs like crap. Stock LS1 motor with long tubes and cold air and rear O2 deletes. Could one of you guys please look at my files and tell me if you can see what I cant? What should I try to fix? Where should I look first?
Thanks!
File Type: hpt
File Type: hpl
File Type: txt
6112011DTCs.txt (796 Bytes, 105 views)
Old 06-14-2011, 07:32 PM
UMD_Jesse's Avatar
anyone?
Old 06-15-2011, 03:39 PM
UMD_Jesse's Avatar
tttttttttttttttt
Old 06-15-2011, 05:51 PM
2xLS1's Avatar
Um, you need help seeing 3817 misfires on Cyl 3? I would look first at Cyl 3. Plug, wire, injector, valve springs...
Old 06-23-2011, 12:43 PM
UMD_Jesse's Avatar
Replaced the plug wires..problem fixed.
However, out of curiosity, are sporadic misfire codes kind normal? Car runs fine after new wires, but when scanning the pcm while driving I might get a single misfire hit maybe every 0 seconds or every minute or so. Though before I was getting hundreds. I figured that might just be a normal glitch or whatever?
Quick Reply: Misfire help. need help interpreting HP tuners logs files
