Need advice
Old 06-14-2011, 11:22 AM
1997transamws6's Avatar
Default Need advice
The 2 other owners put suspension on my car but idk for a fact if its on there. they have receipts but how can i tell if there really on there.
also i was wondering if these are good suspension parts. should i upgrade some or leave some alone? here are the parts
umiperformance:
#201520-R 82-02 GM F-Body Tubular LCA & Non-Adjust. PHB-RED
#3001 64-02 GM Rear Lower Control Arm Bolt Upgrade Kit
#2311-R 93-02 GM F-Body Upper Front A-Arms-Poly-Red
#2002-R 93-02 GM F-body Tubular Subframe Connectors
Spohn performance:
D-19-409 Polyurethane end links
D-7-1137 32mm poly front sway bar bushings 93-02 F-body
D-19-406 Polyurethane end links
Poly-21 21mm rear sway bar bushings
VBandP.com:
KG9310 Camaro front shock 93-97
RockAuto.com
322 904962 Strut Mount
Thank you in advance.
(also car is a 97 trans am ws6)
Old 06-14-2011, 12:28 PM
99SSJarhead's Avatar
Gonna sound like an ***, but get under the car and check.
Most of what is listed is going to be made of tubular metal powder coated either red or black where as the stock parts are stamped metal. They look nothing alike. You can then just go to umi or spohns website and match pieces to pictures for most of it.
The shocks should have a logo on them. The mounts you can't really tell. The endlinks will usually be two poly bushings around a metal washer black or red.
If yo are still having issues, snap some pictures and post them up.
Old 06-14-2011, 07:08 PM
https://ls1tech.com/forums/lt1-lt4-m...-part-too.html
its there now
