Notices
WTB: LS6 coolant crossover
Old 06-14-2011, 01:20 PM
R6cowboy's Avatar
Default WTB: LS6 coolant crossover
Needing a LS6 style coolant crossover pipe and rear plugs. Please respond if you got them.
Thanks
Jarol
Old 06-14-2011, 08:38 PM
outkast6991's Avatar
pretty sure i have a set. i'll check in the am
Old 06-14-2011, 08:52 PM
R6cowboy's Avatar
Thanks outkast.
I'd like to get two LS6 style crossover pipes, one for the front of course and one for the back in lieu of the plugs. But if I have to buy two sets (crossover pipe and plugs), then I'll do it if I can get good prices on them.
Old 06-16-2011, 10:03 AM
UnVMySS's Avatar
You can get the whole set off ws6store for like 50 bucks.cal I just did it with my intake swap. Just an fyi
Old 06-16-2011, 10:12 AM
samckitt's Avatar
Do you know part number? I found somewhere it is 12602548, & from Pace Performance Parts, it is $26
http://paceperformance.com/i-6485108...nder-head.html
Old 06-16-2011, 10:16 AM
Bryceslu's Avatar
Thats it..I believe that is technically the LS3 one but from what Ive read on here it works.
Old 06-16-2011, 10:45 AM
samckitt's Avatar
Is there a need/advantage for putting one at both the front & back of the block? The LT engines had this on the back only.
Old 06-16-2011, 12:14 PM
R6cowboy's Avatar
Thanks for the input
Yeah, the coolant pipe part number for the LS1/LS6 is 12602544. I haven't checked Pace, so I'll take a look. Thanks
Old 06-16-2011, 12:19 PM
R6cowboy's Avatar
I believe on the front the coolant pipe is a must due to the front of the engine sits higher then the rear. I guess that is why its not neccessarily needed on the rear of the block. And it keeps the front two cylinders from getting too hot. But the thing is, it can only be beneficial to have a coolant pipe on the rear as well.
Old 06-29-2011, 12:15 PM
R6cowboy's Avatar
Default update
Now have what I was looking for.
Thanks,
Jarol
Quick Reply: WTB: LS6 coolant crossover
