question on converter
Old 06-15-2011, 08:37 AM
rollingchevys's Avatar
Default question on converter
I did h/c ever since I did that my car hits the rev-limiter and I move the rev limiter to 6600 but feel like the tranns is slipping but my tranns is built and has a 3600 stall
Old 06-15-2011, 09:18 AM
99427camaro's Avatar
what kinda power are you making, what converter are you running, what has been done to your trans
Old 06-15-2011, 10:23 AM
Mystery Bird's Avatar
Did you tune for the converter?
Old 06-15-2011, 01:23 PM
Yeah its tune for the converter but can't get it to stop slipping its a custom converter with billet cover I have no idea how much power its making did a street tune
Old 06-15-2011, 01:24 PM
Car pulls real hard
Old 06-15-2011, 01:32 PM
lemons12's Avatar
What gear are you in when it hits? As in the gear selector.
Old 06-15-2011, 02:13 PM
every gear I need to get off the gas
Old 06-15-2011, 02:25 PM
lemons12's Avatar
When you go wot... what gear is your gear selector in? D? OD? 3? 2?
Old 06-15-2011, 03:09 PM
Always OD
Old 06-15-2011, 03:35 PM
lemons12's Avatar
Try in D (3 for Camaro).
Old 06-15-2011, 03:51 PM
pimpjames's Avatar
The Birds have 3 as well. D is OD for me.
Old 06-15-2011, 04:03 PM
lemons12's Avatar
The D and 3 are different between the Trans Am and Camaro.
Old 06-15-2011, 05:38 PM
Always OD
Old 06-15-2011, 05:45 PM
lemons12's Avatar
Try it in D/3.
Old 06-15-2011, 07:42 PM
I will try that....i was a quart low...lol...maybe that was the problem
Old 06-15-2011, 07:46 PM
lemons12's Avatar
You do have a cooler, right?
Old 06-15-2011, 08:35 PM
I have one but haven't install it I need to figure out if it hooks up to the top line or bottom if the radiator
Old 06-15-2011, 08:42 PM
lemons12's Avatar
Do NOT drive your car again without it!!!
Chances are you have already done a decent-severe amount of damage, I'm sure it is slipping.
With a coverter that size you HAVE to have a cooler. Hopefully you can salvage it.
Old 06-15-2011, 09:03 PM
senicalj4579's Avatar
Mine hit the limiter a few times at WOT and it was after I installed a cooler. I ended up being low on fluid
Old 06-15-2011, 09:07 PM
xX-Z28-Xx's Avatar
From what I hear, it can also damage it with the stock converter. (sometimes) trans coolers are a must!
