el torro prc 2.5 5.3's what do you think ?
here is my setup and dyno graph what do you guys think ls6 intake killing me or just weather.
stock bottom end, ls6 intake, stock fuel pump, stock inj's.
prc 2.5 5.3 heads 62cc.
el torro 230/230 .612/.592 LSA 111+2...
texas speed 7.425 pr's
gmpp head gasket and bolt kit.
no it's locked thats why I asked. I can tell it's alot stronger now than it was with full bolt on's so i'm guessing it was a stingy dyno. the man said he has a car with a fast intake, ms4 , ported 243's and my car put the same power down and more power thru the power curve.
The numbers seem kinda low, but the graph looks very good, right on par with dyno graph. I have the same I/E set-up as you but am running 243 heads. You also have 4.11 gears and its hot as ***** out, so that is eating up some HP right there.
I bet you will do well at the track, this cam is nice as it gives you early useable torque and carries well up top too, here is my graph just to compare.
https://ls1tech.com/forums/dynamomet...411-388-a.html
predator z I changed my fuel pump yesterday to the 255lph walbro and it feels alot better the only run i logged didn't save last night. but here goes my log from the dyno.
well the fuel pump didnt do the trick still 102 to 103 Idc on the runs from saturday. so looks like 36 lb injectors are going to be ordered this week.
Put some injectors on that bitch and then I'll guess 400whp.
I've been doubting this set-up as it seems everyone never gets what they want out of the el torro cam unless everything is perfect. No matter what the master of valve events on here says this cam isn't for everyone.
