Small Block & Big Block Chevy Specific - required parts for tall deck
View Full Version : required parts for tall deck
bugy
06-15-2011, 06:41 PM
hello, I'm planning to get a chevy BB from any aftermarket this is gonna be something like 4.595" bore and stroker kit would be 630 CID flat pistons, crank stroke 4.750" with 6.660" H-beam rods , so i'll need tall-deck and raised cam. manifold, distributor, pushrods and some other parts change because of this right? i could not find manifold for this setup. help!!!!
:bang:
01badz
06-15-2011, 09:02 PM
so your just looking for a tall deck intake like edelbrock 2916 or simmilar? what carb or fuel injection? im sure you would be running rectangle ports. what is your preferance?
bugy
06-16-2011, 11:34 AM
there you go!, it is exactly what i need, yes it'd be carb and rectangle ports, what else do i need for this tall-deck setup? distributor? about raised cam, timing set will be different right?
thanks dude :D
poltergeist 02
06-24-2011, 08:06 PM
with a tall deck setup intake manifold spacers are needed for most aftermarket intake manifolds. if i remember right, i think Dart makes a intake for tall decks.
quick77
06-24-2011, 09:26 PM
Dart makes tall deck intakes ,they come recessed where the dist. goes , that way any std. MS
quick77
06-24-2011, 09:29 PM
Sorry,technical difficultys, was meant to say any BBC/SBC will fit. I would use MSD.
mm8ls1
06-25-2011, 08:59 AM
Use a regular intake and get the moroso intake spaces. Also use an msd dist with a slip collar. John at APD racing carburetors & engines did this for years.
bugy
06-27-2011, 07:08 PM
ok guys i wrote down everything one more thing about raised cam, timing set would be different right?
quick77
06-27-2011, 08:06 PM
No raised cam in a tall deck big block , maybe one with 5 inch bore space,but not an issue for you. What car is this going into,and whats the intended use
bugy
06-28-2011, 12:17 PM
it is a malibu 80, it'll be for drag race
mrdragster1970
07-04-2011, 05:04 PM
I have used a 10.2 many times in the past, and probably still have a dominator intake on the shelf.
You do not need a spacer, there are a few intakes available.
I really ran good with a single dominator edelbrock. 8.50's @ 159, 3200 lbs.
If you are going to be racing this and putting out decent power, I would consider getting a bigger deck.
I have never been a fan of a 3/4 arm in a 10.2.
I'm a little familiar with BBC's, so if you want, drop me a note,
maybe I have stuff you need, or can answer some ?? as they come up.
jbl@jblandsondragracing.com
2 of my BBC's, I have been doing this a week or 2.
http://img27.imageshack.us/img27/5680/hpim0719f.jpg
http://img145.imageshack.us/img145/8108/profilerr7ia.jpg
