10 Bolt Question.
10 Bolt Question.
If I build a 10 bolt would it hold up to the power im making which is about 463 rwhp and 411 trq.
Im talking like moser axles, gear, dif, and all those goodies. Any suggestions?
Save your money for a rear-9 inch if you drag race the car.
Lighten up the car and run low gas levels in the meantime
LPW girdle,solid crush sleeve,weld your axle tubes and run a GM gear set is what you can do in the meantime if you can find the gears(find out who they were set up) and girdle used.
