Annoying high idle
Old 06-15-2011, 11:14 PM
lunatikgixxer's Avatar
Default Annoying high idle
Ok it seems like ever since i got rid of the stock pcv set up my rpms stay around 1000 rpms until i come to a complete stop then they go back to 750... I dont really know whats causing this so im asking for some opinions here. Right now my pcv set up is just 3 long hoses coming off the valve covers dumping off behind the motor up underneath and out the bottom. Any ideas like maybe a spark problem?
lunatikgixxer is offline
Old 06-16-2011, 12:36 AM
99Bluz28's Avatar
Your problem is your current PCV setup.
99Bluz28 is offline
Old 06-16-2011, 07:33 AM
ok i figured it was, so pretty much a catch can will eliminate that?
Old 07-04-2011, 11:25 AM
slayer6x6's Avatar
I seem to be having the same problem after removing my catch can. Did you ever find a fix for this?
slayer6x6 is offline
Old 07-06-2011, 11:46 PM
havent got around to it no but i will probably just route it back the stock way since i dont have any extra money to buy a CC right now
Old 07-07-2011, 04:40 AM
01ssreda4's Avatar
There is a right and a wrong way to do a PCV system. I suggest you search around for the correct diagrams, and route yours appropriately. Because the way it sits now, it is incorrect.
01ssreda4 is offline
