4l60e won't reverse until 1500rpm
Old 06-16-2011, 12:23 PM
bennett28's Avatar
Default 4l60e won't reverse until 1500rpm
I put the car in reverse and it use to roll back if I had the brakes off. Now I have to rev the car to 1500rpm to get it to go in reverse. When I shift the car feels like it doesn't shift with it, feels like it's still in park until I rev to 1500 then it goes backward. Other gears are fine.
Old 06-16-2011, 12:34 PM
AZZKIKR's Avatar
Have you checked the level of your transmission fluid?
Old 06-16-2011, 12:59 PM
bennett28's Avatar
yep it's full at temp.
Old 06-16-2011, 03:14 PM
Mystery Bird's Avatar
Start simple first, check to make sure you cable underneath isn't loose, broken clip, or out of adjustment.
