ls1 crrank vs ls2
Old 06-16-2011, 03:59 PM
Floorman279's Avatar
Default ls1 crrank vs ls2
are these two cranks the same? can i use an ls1 crank in an ls2
Old 06-16-2011, 04:00 PM
a sticky should be made just full of parts interchangibility
Old 06-16-2011, 06:45 PM
gnx7's Avatar
yes..... same crank.... but the reluctor wheel is different.
Old 06-16-2011, 08:47 PM
ok thanks
Old 06-16-2011, 09:13 PM
ok so if i was putting an ls2 into my f body, i can just take my crank out of my ls1 and put it right into the ls2 block because i need the 24 teeth reluctor. isthat statement correct?
Old 06-16-2011, 10:38 PM
litle88's Avatar
That's correct.
Old 06-17-2011, 05:45 AM
Ok cool thanks
Old 06-17-2011, 10:01 AM
Sawzall and Welder Mod
Whistler's Avatar
Many LS2 engines, however came with a 24x reluctor.
All GTO LS2- 24x
2006 Trailblazer SS 24x
2007-up Trailblazer SS 58x
All Corvette LS2- 58x
Old 06-20-2011, 09:29 AM
RyanS13's Avatar
lq4 and lq9 and 5.3 cranks swap as well? or is there a difference with the iron block cranks?
Old 06-20-2011, 10:16 PM
3stgstocker's Avatar
Default ls2 crank in a 6.2
i got a 6.2 from a dealer out a 2010 escalade that the lifters blead the oil pressure off and started to scar crank. i got a good ls2 crank that i can use in it and it has same casting numbers but the ls2 crank is cross drilled all the way thru the main webbing and the 6.2 crank isnt. i know everything else is the same but im wondering if i need to rebalance the motor or not? i know they say that the old school 305 n 350 cranks wont interchange without rebalancing but in stock motors we have rebuilt 100s and never had a problem. anybody done this?
Old 06-20-2011, 11:49 PM
Whistler's Avatar
The truck cranks have solid journals and are heavier, as are the rods heavier. You'll need a rebalance.
Old 06-21-2011, 09:18 AM
Default rebalance
will i ust need to send 1 rod n piston to rebalance crank or do i have to send everthing to get rebalanced
Old 06-21-2011, 11:18 AM
96 Comp T/A's Avatar
All GTO LS2- 24x
2005 Only Corvettes came with a 24x reluctor.
Old 06-21-2011, 06:13 PM
2006 trailblazer ss came with 24 toot reluctor ive owned 1 and worked on several!
Old 06-23-2011, 03:37 AM
blackedout drop ls1's Avatar
what about an 05 ssr. I bought a ls2 longblock last week and was told it was a 06 vette motor. Come to find out it is out of a 05 ssr. anyone know of the top of the head which reluctor is used. I bought the Lengenfilter box but I think
Im not going to need it. Any thoughts would be appreciated. Thanks
Quick Reply: ls1 crrank vs ls2
