Gen 5 Camaro Racing Tech, Results - BMR Launches New Product - 2010+ Camaro Rear Lower Control Arms (TCA028)
BMR Tech2
06-16-2011, 04:21 PM
BMR Suspension
Lower Control Arms for the 2010+ Camaro
Correct lost camber adjustability, reduce suspension deflection, and increase rear cornering stability with a set of Lower Control Arms from BMR Suspension. Superior to the factory stamped steel arm, the BMR Control Arms are constructed from heavy duty 2” square tubing and internally-gusseted laser-cut mounting plates. The BMR Lower Control Arms (TCA028) feature low-deflection polyurethane bushings, reinforced sway bar mounts, and a shortened overall length to correct camber on lowered vehicles. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit BMR Suspension - The Leader in High Performance Suspension & Chassis (http://www.bmrsuspension.com), email sales@bmrsuspension.com, or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrsuspension.com/siteart/products/TCA028_large.jpg
BMR Tech
12-16-2011, 08:52 AM
Just letting you guys know that the TCA028 Non-adjustable control arms have now been revised with wheel reliefs for 17" Weld Drag Wheels. As the market evolves for our G8's and 5th gens, so does the amount of available new products. BMR has always tried to stay on top of things by continually refining our products to be compatible with others in the market. When Weld came out with their awesome new drag wheel for the Fifth gen, it was a no-brainer to work with them on a solution to the control arm clearance issues.
Please keep in mind, we offer no promises that this new revision will be compatible with other 17" wheels on the market as it was designed specifically around the Weld wheels.
http://www.bmrsuspension.com/siteart/products/TCA028_image2_large.jpg
94 guy
12-16-2011, 02:10 PM
these are for a 1" lowered camaro with welds right?
