Tools & Fabrication - "Just in case tool bag"
View Full Version : "Just in case tool bag"
CaMaRo67RS355
06-16-2011, 08:10 PM
Trying to put together a tool bag to keep in the car for when something unexpected happens. So im trying to figure out what should be in it. Ive got some stuff but am open to suggestions.
01ssreda4
06-17-2011, 01:11 AM
I don't typically carry "tools" but I do carry an extra belt, fix-a-flat, and a mini air compressor.
Silverback
06-18-2011, 12:42 PM
depends on the car...
normal car just gets jumper cables, an LED flashlight, a multi tool (cheap knock off leatherman type thing) and one of those flip around 6 way screwdrivers, race car same deal without the jumper cables. Parts chaser/truck/tow vehicle has all that, straps, 30' trucker's chain, a bunch of network cable (use it for tieing stuff down), and my jy crawling tool kit which has a couple of vise grips (one with the 3 sided nut grabbing jaws), a pair of dikes, a cheap socket set that I dont care about loosing...
mpmjason
06-18-2011, 04:32 PM
i go to wallyworld and buy those cheap ass mech tool kits to keep in the trunk.
1BAD02WS6
06-18-2011, 06:33 PM
do you carry tools to put the belt on?
67RSCamaroVette
06-26-2011, 08:59 PM
I carry
1/2" LONG ratchet with a lugnut-sized socket
7mm hex driver
flat+philips tip screwdrivers
10mm, 12, 13, 15, 17mm sockets 3/8 drive
same size ratchet wrenches
Klein crimper/wire cutter
Spare fuses
Maglite
8" and 12" crescent wrenches
Channel locks
Small ball-peen hammer
Duct tape
Fits in my 16x4x6 tool bag no problem (1/2" snap-on flex-head ratchet fits folded inside), never had to call a tow truck.
I drove a '96 S-10 for a while, and I'd never know when I'd have to replace a radiator or pound in a tranny seal on the side of the road, haha. Probably why I carry what I do.
Lots of water bottles on a long (200+mi) trip, just in case.
67RSCamaroVette
06-26-2011, 09:03 PM
You don't need tools to put an F-body belt on :D Left palm pushes on the tensioner pulley, put your weight on it, right hand slides the belt under the water pump pulley.
ScreaminRedZ
06-26-2011, 09:05 PM
I don't carry a general mainainance tool kit in my cars, but I did put together a small tool kit for changing nitrous bottles and jets, that I kept in my Z28.
9802TransAm
06-26-2011, 09:18 PM
.357 magnum and cash. Solved every problem I've ever had.
garygnu
06-26-2011, 10:49 PM
a tire plug repair kit,plug in 12V lite,and a belt tension wrench for the DD .a 9mm has more in the clip.
Anthony Williams
06-27-2011, 12:14 AM
A good set of mechanix gloves, a harbor freight tow rope, a dog bone multi wrench, a multi bit screwdriver, a 24oz. plastic cup, and a tire pressure gauge.
01ssreda4
06-27-2011, 12:27 AM
No, but I figure it is a hell of a lot easier to find a set of sockets then a specific belt....possibly in the middle of the night, or the middle of nowhere etc.
ABeasst
06-27-2011, 07:52 AM
Belt tensioner wrench, extra belt, and a 9mm with a box of ammo.
grunt1152
06-27-2011, 09:01 PM
I have a complete tool set in my car, but thats only due to me working on something every time I turn around. I was getting tired of not having what I needed so I just packed a little bit of everything. Complete set of standard and metric wrenches and sockets, screwdrivers, pliars and vice grips, fuses and electrical connectors. Just a bit of it all.
carcrazed484
06-28-2011, 04:41 PM
I have a complete set of tools as well. Just in case anything happens. Better be prepared than sorry
