fast 102
A FAST 102 will add horsepower. How much it adds depends on what intake you a switching from as well as how well your heads flow.
With regard to cost justification it depends on your perspective. The fact is, the marginal cost of horsepower gets higher the farther down the upgrade path you go. If you are looking to get the same cost per horsepower of your earlier mods, the answer (on the FAST 102) is probably no. If you are willing to accept the higher cost of the marginal horsepower, the answer is probably yes.
