Starter shims
Starter shims
So I just replaced my starter because somehow the housing on my starter cracked... The new starter came with shims in the box, but the old starter didn't have any on it. Am I supposed to use the shims or no?
you need to measure the gear mesh with the new starter........get a wire coat hanger.......you should just be able to put it between the peak and valley of the teeth when they are meshed (roughly .030) space.........you may need to use shims in different spots to achieve this...........never just assume always measure
I really like these back yard solutions to problems,...but there's a BIG difference between the size of a coat hanger and a paper clip,...which one is it guys,...I'm 2 days away from firing my new 383
if u want to get accurate do it the way i did.........grab ur self a .029 welding rod and there ya go.........if not a coat hanger will work for the normal person with out a shop in their back yard.....
