Fueling & Injection - Need Injectors (Cam only LS1)
CranMaro99
06-17-2011, 07:21 PM
Hey everyone.
I just got my car where I want it modding wise. I did a cam only on my 1999 Camaro with a TR230 and all supporting mods.
Long story short I need new injectors. I'm running on the stock fuel system so people are saying that I just need some replacement 36# injectors. I'm new to the fueling/injectors and am not sure which ones to get for a simple replacement that would be easy to tune. I'm all about longevity and reliability.
Which ones should I get? I do not plan on modifying the car anymore than it is but would not mind a bit of leg room. Some people have mentioned names like FAST and FIC.
Thoughts?
ZL1Killa
06-17-2011, 10:28 PM
Some 36# from lucas delphi or straight from Fic injectors i dont know their brand may be same. Any of those will be drop in and change ifr table and go. I would read the fuel and injector sticky to see what the factory pump supports just to check. I know the pump is a 190 liter per hour
CranMaro99
06-17-2011, 10:49 PM
Thanks for the response. I'm totally new to injectors here, and I am hoping to just drop in some injectors and call it a day after re-tuning as I don't plan on modding this car further.
About2Bite
06-17-2011, 11:28 PM
FRPP 30# red top injectors is what I went with, not sure about your camaro but with my 99 C5 they end up being 36# injectors and plug right in. Obviously a new tune is needed but they work great and are cheap. You can find them for under 100 all day on mustang/ford forums.
jc98ss
06-17-2011, 11:43 PM
i have a set of 28.8lb injectors in excellent condition......these are the better ones from 98 F-body's and Z06 Vette's....i got talked into a set of 36lb Bosch for my cam swap, but i don't think i would've really needed them unless i was going to do a set of heads too......i'll sell them to you cheap if you want them
CranMaro99
06-18-2011, 01:26 AM
Thanks for the reply guys. I'd like to just get drop in replacements that will work with my stock fueling system and fuel pump, etc. My mechanic who is works just on LS based cars and has his performance shop recommended FICs I believe? Or maybe I forgot what he said.
Right now my stock injectors are at 100% at WOT
CranMaro99
06-19-2011, 10:32 AM
Would these work as a direct replacement with stock fuel pump?
http://www.corvetteinjectors.com/shop/viewitem.php?productid=322
jc98ss
06-19-2011, 12:39 PM
those are the exact ones i have now, they work great, i'm still on stock fuel system...... there's also plenty of room to grow in case i ever want to install heads
CranMaro99
06-19-2011, 10:27 PM
Ok awesome good to know man. I'm pretty sure these are the ones I'm going to go with.
TrikeMike
06-19-2011, 11:27 PM
It really depends on the car, my car was maxing out stock injectors and stock fuel pump. Fuel pumps are easy to install and cheap.
CranMaro99
06-20-2011, 12:00 AM
Yeah I hear you. I'm going to go with the injectors and see how it works. In general, how much horsepower can a stock fuel pump handle in a 1999 Camaro?
67RSCamaroVette
06-20-2011, 12:28 AM
You ought to see what the duty cycle on your stock injectors is at before you start buying parts... I don't see you running out of injector... I run a much larger cam on 26's and a 255 pump, and have not run out of injector. If you DO need injectors, I recommend FIC..
CranMaro99
06-21-2011, 11:54 AM
I do. I was running at 100 percent duty cycle. It looks like I'm going to go with the FICs as my tuner/mechanic did not mention anything about my fuel pump being maxed out, just the injectors. I guess I'll find out.
ZL1Killa
06-21-2011, 05:08 PM
there is a fuel and injector sticky that tells this. I helped make it.
ZL1Killa
06-21-2011, 05:09 PM
http://farm1.static.flickr.com/133/334889039_ac3da43aa9_o.png
190L/hr factory pump is good for 38# injectors
CranMaro99
06-22-2011, 10:26 PM
Thanks for the clarification. Looks like I'll just be going with the 36# injectors and see how everything works out.
FICINJECTORS
06-23-2011, 09:28 PM
Hey everyone.
Thoughts?
36lb @ 58psi is all you need for your set up.you definitely want to stick with a ls1 base injector.makes tuning a breeze.we offer a couple options. you can send in your stockers in for re sizing.or here's the link for new.
CranMaro99
06-25-2011, 05:28 PM
Just ordered. Thanks!
