New!! and would like some advice.
Hi, I just bought an 05 V. I have already installed cs rear diff bushing (world of difference).It has magna flow high flow cats and exh. I want to put headers on but don't want to buy new exhaust. Will I be able to do that? Since the lt headers will be longer than the stock manifold. Also what do you guys recommend for headers kooks or obx? (Taking the price difference into consideration). Lastly I've seen a lot is people getting the cs engine and transmission mounts, I have no problems now but are they still worth getting?
Thanks a lot for the advice
You can reuse your high flow cats. The connector pipes that come with the OBX headers have either resonators or high flow cats. The set with resonators is significantly cheaper and you can cut those out and weld in the cats you already have. Or if you don't want to do all that cutting and rewelding (or pay to have it done), you could just buy the set with high flow cats already in it and sell the setup you currently have. I believe the OBX set with high flow cats is around $700 shipped.
