Double Roller chain with Melling 10296
Old 06-18-2011, 02:23 PM
lt1773's Avatar
Default Double Roller chain with Melling 10296
Hi guys
i need your help and input to solve the issue of making clearance between the double roller timing chain to the front cover with Melling 10296 I need pics
thanks in advance
the motor is turbo so i do not want to run SLP
Old 06-18-2011, 03:20 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...what-pain.html
Solutions seem to start around post#9.
Also:
https://ls1tech.com/forums/generatio...g-10296-a.html
Old 06-18-2011, 03:31 PM
mark21742's Avatar
Rub some grease around the bolt heads and pump face...also the cast tube that comes out side and goes towards the block....slide the cover inplace without the gasket...pull it back off and grind the spots the grease is stuck to
Old 06-19-2011, 08:09 AM
lt1773's Avatar
any more pics?
Old 06-19-2011, 09:07 AM
cleonard's Avatar
is there not a single chain that is strong enough?
Old 06-19-2011, 09:41 AM
lt1773's Avatar
it is not enough for motor 1000 at the wheel lol..
Old 06-19-2011, 01:12 PM
mark21742's Avatar
Damn I'm only around 650hp to the wheels
Old 06-19-2011, 01:21 PM
JMBLOWNWS6's Avatar
Take your time!
Old 06-19-2011, 02:30 PM
mark21742's Avatar
JMBLOWN, did you take some material off the bolt heads too? I didn't think of that....lol my biggest fear was going too far into the timing cover and breaking through....but it didn't happen
Nice pics by the way!
Old 06-19-2011, 02:58 PM
lt1773's Avatar
Originally Posted by JMBLOWNWS6
Take your time!
means i have to trim or grind the blue mark ?
it seems you have nice setup
thanks
Old 06-19-2011, 03:00 PM
lt1773's Avatar
by the way just you did grinding to the timing cover ? not also to the oil pump?
Quick Reply: Double Roller chain with Melling 10296
