help returning GI
help returning GI
I am returning after a 1 year deployment in iraq. i have 8000 dollars to spend i have a 2002 collector TA it has hooker long tubes true duals, lid and filter, 4.10s in stock 10 bolt, 6 speed The mods i want to make are as follows 12 bolt with 410s, sphon torque arm, Qa1s, spec stage 3 clutch, thunder racings t rex cam package, maf ends ported throttle body,NX NXL kit with the 120 or the 180 shot jets and a roll cage. Will this get me into the 10s or do i need heads also any info would be appreciated.
You can get into the 10's, but your gonna need a little more. Make sure you get a set of relocation brackets for your 12 bolt (Spohn). You might want to consider also investing in a good set of lower control arms, panhard bar, ET Streets/Hoosier QTP's, and a good drag racing rear sway bar (WolfeRacecraft rock!) Be sure to get a bigger intank fuel pump (255lph) and a hotwire kit. Don't forget a good set of headers, some cutouts as nitrous LOVES a free flowing exhaust.
You can probley hit 10's without everything I mentioned, but a few things will have to be added. Think in term of traction first, then power second. All the power in the world will be wasted on a car that won't hook it up to the track.
Welcome back to the states, and thank you for kicking Saddam's ***!! Booyah!
here's what it took for me to run my 10.75:
older heads cam package...about 400 rwhp (a little less now due to a change in nitrous systems and setup for a large shot)
hooker lt's
ory, cutout
12 bolt, 4.10's
cartek clutch
28 inch et drags
bmr torque arm
subframe connectors
6 pt cage (to pass tech)
NX wet kit, single nozzle jetted for a 150 hit
warlboro 340 pump
You can easily do it with a cam. If your car is as heavy as mine, you'll need about a 125-126 trap to run in the 10's. I went 10.8 @ 126 as well.
Good luck!
Conrad
hooker lt's
ory, cutout
12 bolt, 4.10's
cartek clutch
28 inch et drags
bmr torque arm
subframe connectors
warlboro 340 pump
Good luck!
Conrad
btw - watch out with that NXL system, you might wanna look into it before you buy it. I looked into it and eventually decided on the NOS noszle system.
You could easily get away with a NX single nozzle or a TNT kit to do what you want.
the problem with the nxl kit is that it just runs off the stock fuel system. so a search on this system, there is plenty of info on it along with some complaints from a bunch of people about low hp numbers. someone else can correct me if im wrong in all this but if you're only going to spray up to a 150 shot (i mean, you could go more i guess but i don think you'll need to to break 10's), i'm not seeing why people need the NXL kit when you can just buy a cheaper single nozzle system and make the same (or more) power and run the same (or better) times.....
thats why i went with the noszle system over the NXL. I built a stand alone fuel low pressure fuel system for it and hit the stock bottom end with a 260 shot (kids, dont try this at home....i'll be backing down to around 200-210 or so for the track to keep it in one peice). I'm not sure if the stock fuel system with a walboro 340 could supply the fuel needed to run these large shots....and i wasn't about to be the first to find out!
any more questions, just lemme know
Conrad
Conrad
