Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Hood Rattling?
Old 06-18-2011, 07:17 PM
FuzzyLog1c's Avatar
Default Hood Rattling?
After raising and lowering my hood 5-6 dozen times over the past three months, I think I've loosened up a bolt on the driver's side that's allowing the hood to rattle a bit when I drive.
Any ideas? I've tightened the three bolts that I could find (two painted bolts on the underside of the hood, and one covered by a piece of rubber on the side), but the problem persists. If I shut the hood and gently pull up on the sheet metal near the windshield, I can hear an audible "click" (which is what happens during driving, times a thousand).
Old 06-18-2011, 09:13 PM
bamacaddy's Avatar
I don't have a rattle at any "normal" speeds....Although I was on a stretch of interstate that isn't open the other day and did a 150+ run. I honestly thought the hood was coming off. I have made one other pull like this and don't remember any issues...I had at least 1-2" of flex/bouncing in the hood...I had to pull over, clean my pants and check that it was latched all the way.
Old 06-18-2011, 11:04 PM
jenks40's Avatar
Everything on my V rattles. I recomend Hearos brand earplugs, they are sold at many common stores like Walmart and Kmart.
Seriously, have you changed anything under there lately? Don't we have little rubber bumpers like every other american made car that we can adjust to put tension on the hood from the underside? I'm not with my car right now to look at things that could rattle...
Old 06-19-2011, 05:45 AM
STAGEUP's Avatar
It's a bad hood hinge
Old 06-19-2011, 09:00 AM
BudRacing's Avatar
S10's had this problem too. There was a TSB washer used to fix it. Maybe there is something similar for the V... or you could use the s10 part if the bolt is the same diameter.
Old 06-19-2011, 10:32 AM
pharoh's Avatar
+1 The dealer had to replace my drivers side hinge on my 07 last year.
Old 06-19-2011, 01:24 PM
raven154's Avatar
Replaced both hood hinges on my V as well.
Old 06-19-2011, 02:29 PM
JNR_Design's Avatar
Curious what goes bad on them, or it just can't tighten properly (i.e. too much gap) at the pivot point? If that's the case, I would think a thin nylon washer could take up the slop (the one where it pivots, not where the 2 attach the hood)... Perhaps that get bent a little too and/or just a bad tolerance at the factory...Don't know the 'cause, just guessing based on looking at it.
Be glad we don't use a pin-type setup there though, as that's even worse...My vr4 is like that and forced to buy a new hinge or (what I may o) is make something else...
Old 06-19-2011, 04:26 PM
raven154's Avatar
The bolt has a shoulder that fits a hole on the other hinge. The hole gets wallered out and causes it to move around. If you could find a bushing, you could probably repair it.
Old 06-19-2011, 05:47 PM
aurora40's Avatar
I used a thin plastic washer from Home Depot on the hood hinge bolt, this has stopped the rattle.
Old 06-20-2011, 07:21 PM
FuzzyLog1c's Avatar
Aurora, is this the bolt that you dropped a washer into?
Old 06-21-2011, 06:54 PM
aurora40's Avatar
Yup, that one. You don't have to take the bolt out, just back it off a little. And cut a line in the washer so you can slide it over.
Old 06-21-2011, 08:13 PM
lubelizard's Avatar
If the hood hinge is bad, would grabbing the hood and shaking it reveal the rattle noise?
Old 06-24-2011, 06:03 AM
babrown18's Avatar
yeah.. i had that problem too.. a washer does the trick..
Old 05-04-2016, 09:27 PM
gatesjeff33's Avatar
Thumbs up
I got this problem too. It wasn't a gradual failure, all of a sudden I thought my hood was unlatched as I was driving down the freeway.
Old 05-04-2016, 11:23 PM
Bio248's Avatar
sounds like you didn't try anything and google took over, but failed.
why did you not pull and pry on your car to see what moved?
Old 05-04-2016, 11:44 PM
Mercier's Avatar
I had this sound as well. My first thought was low wiper spring tension and the wiper was fluttering up and down on the windshield as air passed over/under it. Then I thought hood but that was tight... Turns out that the plastic cover piece on the cowl is loose from the far driver side mounting point/hole cracking. So at speed air flowing over the hood makes this thing flap and rattle. Easy to check. On mine that whole piece around the wipers is a bit loose. Currently bigger projects on the car.
Old 05-05-2016, 11:55 AM
BudRacing's Avatar
I had that flapping for years when I first bought my car. I didn't want to cut the plastic and I had/have other priorities for fixes, but recently I decided "fock it" and cut the loose pieces off. Problem partly solved. Now the cowl is just ugly.
Old 05-05-2016, 12:33 PM
Mercier's Avatar
I am telling myself I am going to hit the Chinese Freight for a plastic welder and do some magic there one day but I wouldn't bet my lunch money that I won't end up just ripping the thing off.
Old 05-05-2016, 04:50 PM
raven154's Avatar
I picked up a used cowl at the u pull for 20 bucks. Looks a lot better than the original.
Quick Reply: Hood Rattling?
