Drag Racing Tech - Running a 12 sec index with a 11 sec car...
Humanoid
02-27-2004, 08:55 AM
Running a 12.00 sec index with a 11 sec car...
What is the best strategy for slowing down about .5 consistantly?
I have no cage so I cant run in any of the classes that call for me to make <12 sec passes.
I know the is a newbie question so please excuse.
My car is MTI H/C ,X1, Yank SS4000, 16X26 ET streets
WicketMike
02-27-2004, 09:17 AM
i would guess you would have to find the spot on the track where you coast the rest of the way from or tap the brake if its legal
Tom the roofer
02-27-2004, 10:15 AM
I did this in the NMCA EFI index class last year and I lowered my launch rpm's and lowered my shift point quite abit. You still want to be about 1/2 a tenth to a 10th faster than the index and coast through the traps starting at a given point like maybe the 1000' mark. Worked for me. I won 1st place in Pittsburgh.
Good luck.
Tom
DMcRacer
02-27-2004, 10:21 AM
If your talking about running at the SBSO, I believe its at an IHRA track. I think you can run 11.5 with no cage. You can always add some wieght to slow the car down. Full tank of gas, full wind shield washer tank, etc.
gator's 99TA
02-27-2004, 10:50 AM
dood. if you are even thinking of competing (or qualifying) for a bracket class, you need to have major seat time. practice practice practice. your first couple of events might not be exactly like you planned. lol. you need to know exactly how your car runs, when to lift, where to lift, and hitting a great reaction time.
Turo
02-27-2004, 11:32 AM
just an indea, but go to the track and start adding some weight to the car (not sure how, throw something in the back?), but drive the car like you normally do, until you get your desired et. just a thought, good luck!
NRC-Motorsports
02-27-2004, 11:49 AM
My car is MTI H/C ,X1, Yank SS4000, 16X26 ET streetsdo like the pros do get a throtle stop,so you dont have to guess what your doing,if you watch,super gas,super street,super comp cars [nhra]you,ll see throtle stop go on pretty much right out of the gate ,this is so they can kill et ,but not hurt mph to much,because if your running the car to go 12.oos you,ll have to chase everyone so the last thing you want to do is hurt your mph,you want to be coming up on and force the slower car to breakout
:drive:
Bob Cosby
02-27-2004, 02:03 PM
Do everything normal, but stay only 1/2 a fender in front of your competitor. Hope he/she is not doing the same thing.
CamaroCain
02-27-2004, 06:00 PM
James and Sheila (TXCAMSS) has done it before, may want to find them in the Texas forum.
Are you just not wanting to ever put a roll bar in the car? Why not put a roll bar in and try to be right at the 3350 raceweight limit??
TwoFast4Lv
02-28-2004, 01:43 AM
easiest way is to do a combination of the ideas above.
Lower the launch to a VERY consistant RPM and then drop shift RPM to a good level to not stress it as much.
Then take and build a Throttle body stop so you only hit say 80% throttle every time.
Always leave some room for a run at the end ;)
Humanoid
02-28-2004, 03:44 PM
Thanks for the ideas. I think I need to play around and find out what will do it. I will try a combo of the above.
gator's 99TA
02-28-2004, 06:01 PM
what has the car (and driver) gone consistently? not meaning cars like yours, just your particular combo. that is the first place to start.
SMOKIN01TA
02-28-2004, 09:41 PM
hey humanoid, ill see you there in the same class doing the same thing so i cant tell you my secerets. :jest:
im getting a low 11sec car to run 12.0 :cry: im deabating putting the stock cam in and running the slicks and new gears only if the other plans are to hard.
foff667
02-28-2004, 09:56 PM
if youve got edit you probably could pull enough timing to loose that much in the 1/4 just one more thing to consider
95 Formula
02-28-2004, 10:54 PM
add weight(full tank, seats, etc.), tape up part of your intake.
x phantom x
02-29-2004, 12:35 AM
haha ... that's classic.
I can just see the 2 cars volleying back and forth, one goes in front, slows down, the other goes in front, slows down ... etc
:jest:
