MIKE93SVT
06-19-2011, 11:55 AM
i can't decide between 2 different combos. and it's time to start gathering parts. i'll list the facts below, and my 2 different ideas. please help me choose one over the other.
Car:
1995 mustang, fully built chassis (cage, mini tub, full suspension, etc.)
th400, w/ trans brake
big fuel system
has 3.27 gears, but can be changed easily
i have an lq4 longblock sitting in the garage. stock with 60k on it. also have a carbed cathedral port intake, but can swap with no issues
anyways, i am looking for this car to be driven to the track, run mid-high nines and drive home. plan to run e85 to help with this goal. car should weigh around 3100-3200 lbs
i don't have unlimited funds to finish the motor, but won't take big short cuts to do it. i'd like to do an n/a motor for simplicity and less things to worry about. same reason the car will be carbed for n/a or turbo. pro systems or csu will get the job done. so, please help pick the setup
keep the stock longblock, usual upgrades... rod bolts, timing chain, custom cam, valve springs. add a good turbo and run with it? e85 will allow a large pillow for tuning and boost, and i know i can hit the times i'd like. i've had turbo cars in the past and just got tired of the small things breaking, melting etc
or grab some l92 heads, and do some forged pistons/rods to raise the compression to like 13:1, get a custom cam that gets the top end power i'd need. possibly add a 100 shot to get mid 9's?
i figure money i'd spend on turbo, pipe, wastegate, bov would be similar to rods/pistons and machine work. wouldn't be exact, but i'd fab the turbo setup myself. just curious if the n/a 370 can get the power down with high compression.
thanks,
mike
let me know if i'm leaving anything out. i'm in afghanistan, it's late evening and i'm fuckin tired
Car:
big fuel system
thanks,
mike
