Injector Ohm Testing
Old 06-20-2011, 10:04 AM
zarco28's Avatar
Cool Injector Ohm Testing
so i tested my injectors on my 94 lt1 assuming it should be the same for ls1s? my driver side injectors are constent 14 OHMS straight and the ones on my passenger side read 17-18 Ohms im wondering if this is normal or are all 4 on pass. side blown? i do have a misifire on lower rpms(1000-3000k) and clears up after that.
Old 06-20-2011, 08:53 PM
FICINJECTORS's Avatar
Lt1 injectors should be 12.8 ohms. 18 is not right unless they are 92 lt1 injectors the part number should be Rp 17121068
Old 06-20-2011, 09:48 PM
zarco28's Avatar
Thanks maybe they did put 92 inj in there to maybe get the car going cus I saw that the 94 changes in sequential injection ill check the part numbers.. if they did put 92 inj does that mean they shouldn't be there?
Old 06-24-2011, 12:09 PM
let me know what pn they are
Quick Reply: Injector Ohm Testing
