7.1 @ 95 w/stock lq9/tsp tsunami cam. Any idea where this motor peaks?
Old 06-20-2011, 03:36 PM
dville_gt's Avatar
Default 7.1 @ 95 w/stock lq9/tsp tsunami cam. Any idea where this motor peaks?
Took it out on Friday to Texas Raceway (local 1/8th mile), it was 97* at 10pm! Car went 7.1 @95 w/a 1.53 60' (still need an anti roll bar). Motor is a stock LQ9 from a 2005 Escalade w/a th350 and 4400 stall (this is in a mustang coupe btw), all it has:
1 7/8th longtubes
TSP Tsunami cam
TSP pushrods
My buddy said it sounded like it was nosing over before I shifted at around 6600 (not actually completing the shift until around 6800). On the 7.1 I short shifted 2-3 shift and it obviously didn't hurt anything. I really want a 6.9x on this combo (which in better air I think would be possible).
Where would you shift this at considering I am still running the stock 317 heads?
Here is a video btw:
[youtube]ycgBhnFPIuQ[/youtube]
Old 06-20-2011, 07:38 PM
b_evans06's Avatar
I have a very similar combo as you do but in a little heavier car. I have an lq9 with a tsunami cam that is carbed with a th350 and 4000 stall. I can feel mine nosing over as well over 6600 rpms. I watch videos of mine run and can hear the difference. I try to shift mine around 6500 at the track. I don't have any dyno numbers so I am not sure where the peak power is at.
Old 06-20-2011, 07:46 PM
dville_gt's Avatar
Ya, no dyno #s here either. What kind of car is yours in and what does it run?
Old 06-20-2011, 08:00 PM
b_evans06's Avatar
It is in an 84 oldsmobile cutlass. It has ran a best of 7.36 @ 93 so far on a drag radial and weighs 3400 with me in it.
Old 06-21-2011, 09:45 AM
dville_gt's Avatar
Thats a good time. What are you shifting at?
Old 06-21-2011, 09:54 AM
TooLateVTEC's Avatar
What did it run prior to short shifting it?
If you shifted early and it picked up ET, than you know you need to shift earlier all the time.
Old 06-21-2011, 10:08 AM
dville_gt's Avatar
If you listen I only short shifted 2-3, I meant to shift 1-2 early but forgot. The other runs were around 7.2-7.3
Old 06-21-2011, 10:19 AM
I know, I heard that.
So you shifted early on one gear change and it picked up a tenth which tells me the 1-2 needs to be shifted a little earlier as well.
I would start shifting 200 RPM earlier each pass until the ET either doesnt change or starts slowing down.
Old 06-21-2011, 10:23 AM
Fbodyjunkie06's Avatar
Yea you need to bring your shifts down at least 200rpm. Try that again, and then if you want to you could get creative and try another 100-200rpm. Obviously if it picks up speed and e.t. then you know your not making power as high in the rev range as you thought.
What LSA is the tsunami ground on? And is it installed straight up? I know the specs are 233/239 iirc?
Old 06-21-2011, 10:30 AM
slowlsx's Avatar
Negative.. The are 235/240.. I think on a 111 or 112
Old 06-21-2011, 11:07 AM
dville_gt's Avatar
it is on a 111 and is installed straight up
Old 06-21-2011, 11:58 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Have any of you who feel it "nosing over" after 6500rpm dyno'd your vehicle? What rocker arms are you using? Curious if it is a valvefloat issue, because that cam will pull well past 6500rpm if your valvetrain is stable!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-21-2011, 01:33 PM
dville_gt's Avatar
Stock rockers, TSP 7.425 P/R's, Stock Rockers, Lunati .650 dual spring kit.
Never been on a dyno, tuned on the street w/my buddy, a wideband, and a laptop.
Old 06-21-2011, 05:12 PM
b_evans06's Avatar
I have the tsunami kit from tsp with prc duals and comp pushrods. Stock rockers. I think mine may be nosing over due to jetting in my carb. Mine is installed straight up as well. I try to shift around 6500 with my th350. The car has never been on a dyno.
Quick Reply: 7.1 @ 95 w/stock lq9/tsp tsunami cam. Any idea where this motor peaks?
