Dakota Digital TH350 Speedometer Pulse Generator Wiring
Old 06-21-2011, 11:28 AM
dville_gt's Avatar
Default Dakota Digital TH350 Speedometer Pulse Generator Wiring
I am wiring in the a Dakota Digital Speed Pulse Generator. It has two wires, a black and a grey. The black is for a "ground" and grey for "signal". I assume that the the black would go to the "VSS low signal" and the grey goes to the "VSS high signal" (pin 20/21 on the green connector).
Can anyone verify this?
Old 06-21-2011, 02:37 PM
LS1MCSS's Avatar
Try it that way and see if it works. That's most likely correct, but if it doesn't work, just swap the two wires. It won't hurt anything if it's backwards.
Old 06-26-2013, 11:05 PM
Taubr Unit's Avatar
Digging this up from a google search. Did this work? I have a th350 in my car and trying to use my stock gauges.
Quick Reply: Dakota Digital TH350 Speedometer Pulse Generator Wiring
