Daily use transmission for 850rwhp+ ??
Hello
I own an 2000 Firebird TA
The engine is an H/C 427 with a lots of Nitrous spray which will make 850+rwhp
My A4 Transmission wont hold that power.
Any suggestions? how about the FLT stage 5 extreme transmission can that help ?
Thank you.
Thank you.
Built RPM or FLT 4L80E. Ditch the 4l60e built or not. Believe me I know. You can do a built th400 and sacrifice not having OD or the 4l80e which does have OD but is pricey, but worth it for your power level. Good luck
Art Carr has the 200-4R handling over 1,000 horsepower... I'd bet it's a heap lighter than a 4l80. Check their prices. $1500 for an 800 horsepower unit. The transmissions are full hydraulic if I remember, so no pcm is needed to run them. Could be a perk.
Do you know of any Art Carr units that have several hundred passes on them and LIVED.... I don't. Go with the 4L80E from Jakeshoe or RPM Transmissions and stay away from the advertising nonsense.
