HPS Wicked Stick 2-407rwhp-389rwtq
Stock LS1 C5 Corvette with Headers,Catted X-pipe,Corsa Mufflers and a CAI.
We made some changes to our "Wicked Stick" by adding 1 deg. of LSA and having 4deg. adv. built in.
Results are 407rwhp and 389rwtq in 100deg. air temps.
Chris
Chris
This was from another post:
1. HPS Holeshot
SPECS: INT. LIFT .59?-EXH.59? Duration @.050 INT 22? EXH 23? with a 112 LSA
2. HPS Wild Child
Specs: INT. LIFT .60?-EXH..60? Duration @ .050 INT 22?-EXH22? with a 112 LSA
3. HPS Wicked Stick
SPECS:INT. LIFT .62?-EXH..62? Duration@.050 INT 23?-Exh 23? with a 111 LSA
4. HPS Glue Maker
SPECS: INT. LIFT .63?-EXH..63? Duration@.050 INT 24?-EXH 24? with a 111LSA ""Must check PTV Clearance with this camshaft!!!""
1. HPS Holeshot
2. HPS Wild Child
3. HPS Wicked Stick
4. HPS Glue Maker
The headers are kooks headers. 1-7/8. The specs are 623lift on intake and exhaust, 239duration intake and exhaust on a 112 lsa with 4deg. built in.
The cam is a little large for the ls1 heads and intake, however the customer is upgrading them shortly so he wanted to go big on the cam now and grow into it.
Chris
Chris
