(96 lt1)Trying to get the opti off and need some help
Old 06-22-2011, 09:38 PM
BowtieGirlZ28's Avatar
Default (96 lt1)Trying to get the opti off and need some help
Do I have to pull off the Harmonic Balancer? If so, do I have to have a puller or some kind of removal kit? I have gotten 3 bolts off of the opti but can't feel/see the rest...
Old 06-22-2011, 09:52 PM
IronOutlaw's Avatar
Harmonic Balancer needs to be taken off. I got mine off with a hammer. I just easily pried around it until it came off. Mine had been recently removed so it came off pretty easily, if yours has never been off you may need to rent a puller. The actual crank hub behind the pulley doesn't need to come off though.
Old 06-22-2011, 09:59 PM
Thanks, I doubt mine will come off with a hammer lol
Old 06-22-2011, 10:07 PM
LSWHO's Avatar
There is no harmonic balancer so don't try to remove one.
You can take the crank pulley off and pull the opti without pulling the hub.
Old 06-22-2011, 10:27 PM
License2Ill's Avatar
ok ok ok dont get confused with above post...the pulley is in fact the balancer....it does need to come off...but you can unbolt the 3 bolts the hold it in place to the hub and then proceed to take off the opti. I dont recall if it gets tricky to remove the 3 bolts but it can be done....and the pully/balancer comes off without a puller. but some times u have to pry it off its stubborn.
Old 06-22-2011, 10:37 PM
So do I just mark the hub and balancer, doesn't it have to go back on a certain way? Oh, thanks for the help guys
Old 06-22-2011, 10:40 PM
Badazz 97 TA's Avatar
it can only go on one way otherwise the holes wont line up. just remove the pulley. its a seperate piece from the actual hub that slides on the crank. it comes off pretyy easy with a puller.
Old 06-22-2011, 10:47 PM
fex77k's Avatar
This is what your doing.
Old 06-23-2011, 01:31 AM
BackInBlack02's Avatar
So if the holes only line up one way, then the timing mark (arrow) is always right? or can it still be 180degrees off?
Old 06-23-2011, 06:02 AM
Village Troll
SS RRR's Avatar
Since the hub is not keyed you should never depend on the arrow to tell you where TDC is. If running the opti there really is no need to use TDC for anything except one certain valve adjusting procedure.
Old 06-23-2011, 06:22 AM
moehorsepower's Avatar
You did take out the center bolt correct?
Old 06-23-2011, 06:32 AM
shbox's Avatar
You don't have to when removing only the pulley.
Old 06-23-2011, 01:01 PM
Doh!, You are correct. been so long since I had to replace mine, Thank Goodness......
Old 06-23-2011, 01:07 PM
quik95lt1's Avatar
good lord the info in this thread..........first off dont even go near the balancer with a hammer to remove it lol............go down to your local auto parts store and rent a puller........its really easy to use....pull the balancer off and theres three bolts to take the opti off......then the opti will slide right out of the machined bore in the nose of the camshaft........when yout put it back together be sure to look at the clover leaf pattern on the back of the opti and line up the pin in the cam with the hole with the little square indexing mark on it............also when you put the opti back on i would replace the timing cover seal while you are there........its cheap and easy and can prevent leaks down the road......good luck with your project!!!
Old 06-23-2011, 01:12 PM
whytryz28's Avatar
I was able to yank my balancer off by hands, I also deadlift 500lbs tho
Edit: Quick you got no space bar man? lol
Old 06-23-2011, 01:16 PM
quik95lt1's Avatar
haha yea i can lift quite a bit too but i cant pull mine off lol........
what u mean i have no space bar? lol
Old 06-23-2011, 03:35 PM
Camaro350Z28's Avatar
spray it down with some pb blaster let it sit for an hour, then smack it a bunch with a dead blow itll come off without a puller.. they just get crusty and stick a little you dont need to get a puller
deleted below post.. didnt see 96 in the title
Old 06-23-2011, 04:53 PM
Village Troll
SS RRR's Avatar
For the record the LT1 does not have a balancer. It is a damper. Pretty significant difference.
Agreed. Once you get a little play/wobble out of it then you can work it off pretty easy. Just make sure to have a good grip on it once it decides to break free.
Old 06-23-2011, 06:07 PM
Yes, I think I will take your advice and change the seal, I think I will be putting a new radiator on too, might as well. I will be spending some time cleaning everything up, I believe that seal is prolly already leaking, it's a mess for sure! You have such a cute grin
Old 06-23-2011, 07:45 PM
nascarnate326's Avatar
After the 3 bolts are out mine comes off by hand.
Good thing, this car has enough issues..
Quick Reply: (96 lt1)Trying to get the opti off and need some help
