Cam size?
Cam size?
01 ls1 formula 4k stall stock 3.23 gears long tubes ory lid maf 85mm tubular panahard bar and control arms (umi) relocation brakets subframe connectors stock 241 heads and stock ls6 intake
The car is still a daily driver need a cam that would match well..even if I need more gear just give me idea of duration and lift
I agree with always2slow, is look for something around a .595" lift, once you go over .600" your valvespring life will decrease...unless you don't mind changing valve springs every year
I'd recommend 3.73s also. A low 230s duration cam would work great with that stall, but its better to have a stall thats alittle higher than you need rather than a stall that's too low
A lot of good cams so far but it all depends on what your looking for do you want something that's going to have a strong low end mid or high end? Street manners mpg hp trq are all going to play a different roll in which cam you get. If your looking for cam in the 230's range I have a f13/f14 cam for sale. Its a 230/234 598/598 114. Good luck keep us updated on what your looking for and what you get.
