Tunder Racing TruTop level 3 VS CheaTR v.3 camshafts
Old 06-23-2011, 07:54 AM
Dossary M's Avatar
Default Tunder Racing TruTop level 3 VS CheaTR v.3 camshafts
"TR TRuTorq" Level 3 - 223/236 .612/.610 115 LSA 1800- 6800 RPM Power Band
Or
" CheaTR v.3" - 219/230 .607/.604 117 LSA. Off Idle-6800 RPM Power Band
Any advice for this cams from thunder racing for my ls1 04 holden commodore casue I think I will go with cheatr v.3 cam
other modes :-
Stage 2 Ls6 from TSP heads 64cc Chambers comes with Dual Valve Springs650”
102 FAST intake Mainfold
Nick williams 102mm TB.
SLP catback- headrs
SLP Timing Chains
SLP oil pump
OTR air intak
ARB head bolts
push rods 7.400” from trick flow.
040" Cometic heads Gasket
3.73 geare
ACEL 30lbs fule injectors.
I’m going to start my broject next week so please If you have any advice befor I start plese tell.
Old 06-23-2011, 08:28 AM
mark21742's Avatar
Id go for the trutorq...are you manual or auto?
Old 06-23-2011, 12:30 PM
Dossary M's Avatar
auto , what about ohter modes
Old 06-23-2011, 12:36 PM
mark21742's Avatar
you'll want a 3,600-4,000 rpm stall and tranny cooler before or at the same time as your cam swap
Old 06-23-2011, 12:40 PM
Fbodyjunkie06's Avatar
Originally Posted by mark21742
you'll need a 3,600-4,000 rpm stall and tranny cooler before or at the same time as your cam swap
Corrected
Old 06-23-2011, 12:50 PM
Dossary M's Avatar
Sorry I did not understand could you please explain more ......
Old 06-23-2011, 12:55 PM
Dossary M's Avatar
i have a tranny cooler for TCI . if mean the additional coler for the tranny oil ...
for ( you'll need a 3,600-4,000 rpm stall ) in need an explaination pls.
Old 06-23-2011, 12:59 PM
mark21742's Avatar
With a larger cam your car will be a pain to drive, want to pull through the breaks and or really bog down with the stock stall (torque converter)
Stock stall speed is somewhere between 1,400-1,600.....and you will want a higher rpm stall so the engine can slip and rev higher to keep it were the new can makes power.
Old 06-24-2011, 01:39 AM
Dossary M's Avatar
thanks now i got it
Old 06-24-2011, 01:41 AM
Dossary M's Avatar
please if any one has i good ideas my all setup plese tell me
thanks .
Old 06-24-2011, 04:20 AM
vettenuts's Avatar
Thunder Racing is a forum supporter, why not shoot a PM to Shane (XtraCajunSS) who works for Thunder and get his input. He installs a lot of these cams and can probably best advise you.
Old 06-24-2011, 04:34 AM
PREDATOR-Z's Avatar
Also, check your KSA laws regarding passing annual exhaust tests with higher overlap cams. The Trutorq is -0.5 overlap (It will thumpthump more than CheaTR V3/ -9.5* overlap).
Both will work with stock stall, but CheaTR is more friendly.
Old 06-24-2011, 05:04 AM
Dossary M's Avatar
thanks, i realy Appreciate your help ..
Old 06-24-2011, 05:08 AM
Dossary M's Avatar
I will post my dyno numbers as soon as I finish the swap
thanks again .
Old 06-24-2011, 10:07 AM
tpunk's Avatar
You may also want to check out the small EPS cam. It is much easier on the valve train than the cheater. I'd talk to pat before picking an off the shelf cam from them though. Nothing wrong with the TR cams just have to build up the valve train a bit more for them. Thunder is a great company to deal with as is EPS, so no worries either way.
Old 06-24-2011, 11:10 AM
Do not let anyone talk you into using your stock stall with a cam swap. Even if its a baby stall for your baby cam, there is no point unless you like hearing yourself talk, which is obviously what people that swap a cam in there car without putting a stall in it first like to do. Since all your doing is listening to your car make a lot more noise, but you can't put that new power and all that noise to good actual use, just like running your mouth and not doing anything about it does.
Please get a stall converter, you seem set on doing this the right way, get a stall.
Old 06-25-2011, 02:01 AM
Dossary M's Avatar
Actually I don’t know about the stall converter cause I drive this car dilly you know so h have doubt.
Ok what about the 3.91 gear instead of 3.7 is it going to work better .
Even If I intend to get a stall converter what stage or what….. do I have to install …
Old 06-25-2011, 05:13 AM
2slow2flurry-ous's Avatar
What is it with middle eastern guys and stock stalls on cam swaps? Second one I've seen this week. That cam will suck w/o a stall. Just get a 2800 tci. Cheap easy not bad to daily drive on.
Old 06-25-2011, 07:20 AM
mark21742's Avatar
Don't be afraid s a higher stall converter....I daily drive mine with a 4,000 stall....and love it. Young only need a stall but, you really want one too, you just don't know it yet. Once you drive a car with a stall you will know exactly what I mean
Old 06-25-2011, 07:38 AM
A.R. Shale Targa's Avatar
For What Its Worth....stealth cams are designed for stock heads, intake, and
manifolds....the OP has awesome heads, intake, and headers. I agree he
should get a stall (at least a 3200) but a single pattern cam would be more
suited. He also has a pretty decent gear ratio. My thought is TSP 220 if dead
set on staying with stock converter, or TSP 228 (maybe EPS 226) for the mild
stall combo. Also a decent tune would make these cams idle relatively smooth
....not stock but still fairly stealthy
Quick Reply: Tunder Racing TruTop level 3 VS CheaTR v.3 camshafts
