Pontiac GTO 2004-2006 The Modern Goat
Saggy butt
Old 06-23-2011, 10:29 AM
LS_Style011's Avatar
Default Saggy butt
I have a 2004 gto. Just seeing if I can get some recomendations to fix the drop in my rear end when I get on it? Thanks everyone.
Old 06-23-2011, 11:03 AM
impulsegoat's Avatar
Remove the LS1 and drop in a 1.5 honda engine and you should be good
Old 06-23-2011, 11:37 AM
04gto5.7's Avatar
Cheap fix bmr drag bags....for a really nice fix pedders drag or whatever u perfer springs
Old 06-23-2011, 11:38 AM
Death{AW}'s Avatar
I would go with Lovells springs. They are cheaper and in my opinion handle better :-D
Old 06-23-2011, 01:38 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Like mentioned you can use our BMR drag bags to not only help with the back end of the car dropping when you are accelerating but they will also help out immensely with the wheel hop. The drag bags are easy to install and inexpensive.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 06-23-2011, 01:53 PM
OnyxY2KSS's Avatar
Instead though I went with BC coilovers on all 4, Lovells springs would work fine as well. Unfortunately we all suffer from saggy stock springs eventually.
Old 06-23-2011, 02:39 PM
Death{AW}'s Avatar
I had Lovells but since I am AutoX and roadracing I did upgrade to Kings HHD but for DD and spirited driving Lovells are great.
Old 06-24-2011, 01:37 AM
pctek's Avatar
My 05 goat with 47,000 miles on it when I bought it around last september already had the common sagging rear springs issue. So I just replaced stock springs with stock height lovells myself, it was easy btw and rides great now. It has a better natural stance now since it raised the rear a hair like it should be. It just feels better, now I just need to do the front soon.
I dont auto x or drag, I use it as a DD car so if you DD the goat then just get the cheaper price wise lovells.
Old 06-24-2011, 09:21 AM
svede1212's Avatar
I have Lovells 20mm drop springs AND drag bags and altho the car handles and accelerates fine the back end still squats down when I get on it hard. It is noticeably less than the weak stock springs did but they'll always squat and go a little bit.
Old 06-25-2011, 02:13 PM
LSWONGTO's Avatar
My drag bags finally cured my wheel hop after doing a full pedders rear suspension & Harrop diff cover. One of the best mods I ever did and the least expensive.
Old 06-26-2011, 01:34 PM
nick.celis's Avatar
+1 on the drag bags, i have a stalled A4, so wheel hop was never a huge issue, but the saggy rear end was! I put the drag bags in, and no more saggy rear end, and the little wheel hop i have is gone! the BMR drag bags are well worth EVERY penny
Quick Reply: Saggy butt
