Homemade block off plates
Picked up a piece of 2 inch wide by 1/8 inch thick aluminum from home depot. This should work for block off plates correct? I just gotta cut them and drill the holes for the bolts. Ill reuse the gaskets and throw some high temp rtv around it to make the seal.
i just pulled the old flanges off of the air and egr, then plugged and welded up the holes.
put them right back on with the gaskets that came with my header gaskets
simplest solution IMO
