Which Drag Shocks to Get Better 60's
My Current set up is Stock with solid mount non ajustable Torque arm and mac lower control arms.No on my pump #6 3200 Vigilante converter,the be 60 footer I can muster up is 1.808?I was told I should be running in the 1.6'sSo without Breaking the Pocket book Which Drag shocks do you guys Recommend?
TIA
TIA
Vig 3200, 26-8.5x15 ET Drags on 7.5" Convo-Pro's w/3.23's. 1.67 sixty ft. times. That's w/stock f&r shocks, V6 rear springs ('95 F-body), rt. side airbag, disconnected frt. swaybar. Hoping some good shocks will give me low 1.6's or even high 1.5's....WJ.
i dont know whats wrong with my car but i have a bmr track pack(torque arm + x brace), lca's, panhard bar, subframes, bfg's, and ~3000 stall converter and the best i can pull is 1.8's.
my friends are telling me to buy lakewood 70/30 rear shocks from jegs or summit or something and their like $45 a piece. i think ill try them out and if i dont like them ill probably go with hals.
I have the HALs on my car & they certainly stiffen the rear during launch. But just spinning almost sounds more like your torque arm is adjusted wrong, giving you the improper pinion angle. Have you tried adjusting it nose down a little?
Did you unbolt the Front Sway bar? That helped me get some better 60ft's this weekend..Seems like your air pressure is to low..Try 17lbs & go from there..Maybe run more gas to put weight back there..It might slow you down but it might not..On my 98 T/A I have Mac headers, Lid, Cutout, LCA's, Yank 3500, Tuning, 3.42 Gears..My best 60 ft on MT ET Streets is a 1.77.I was doing 1.80's this weekend compared to 1.84's the month before..
