PCM corossion. How can I clean this up? Pics inside.
Old 06-23-2011, 10:16 PM
94Z28-MSTGKLR's Avatar
Default PCM corossion. How can I clean this up? Pics inside.
So I've been having an issue with my car and I figured I would pull the PCM out and clean it up. Good thing I did. I have pictures of what I found. How can I clean up these pins? Anyone know or have an idea?
Old 06-24-2011, 04:53 AM
2xLS3's Avatar
Soda blast it
Make sure the case is grounded so the static from the blast nozzle doesn't poof the PCM
Old 06-24-2011, 05:03 AM
Chevycrew's Avatar
Small pipe cleaner brush, then a thin coat of dielectric grease?
Old 06-24-2011, 05:26 AM
2xLS3's Avatar
Have fun trying that
First you'll have an issue finding a pipe cleaning brush small enough and next you have trouble doing it without bending the pins
You can find little contact cleaning brush set, but I've never been impressed with their performance and they cost around $40 for a set, I don't feel they're good for anything other then cleaning the contacts on trailer connectors
To the OP, did you pull the plactic retainers from the connectors and see how bad that side is?
Old 06-24-2011, 06:06 AM
Camaroz's Avatar
That's not that bad. How's the connector's look?
I would try some electrical contact cleaner and work the plug's in and out. Then you can blow out both with some compressed air after you loosen the corrosion up.
Old 06-24-2011, 11:39 AM
flame's Avatar
Be lucky you found it now. I had a pin rotted right off. Torque conveter lock up was getting really erratic which is what lead me there. Ended up openning the case and pushing enough through to work again.
Just use some electrical contact cleaner spray and compressed air. Then use some dielectric grease to prevent further corrosion. Check to make sure the female terminals are cleaned too.
Old 06-24-2011, 12:20 PM
The female side of the connector looks okay. It did have water in it and some dirt but it was fairly easy to blow out with some canned air I had for my keyboard. Where can I get some electrical contact cleaner and dielectric grease? I know what the dielectric grease looks like but what does the contact cleaner look like and where do I need to go get it?
Old 06-24-2011, 01:46 PM
patSS/00's Avatar
Dielectric grease is an insulator, generally not a good idea to use it on things that are supposed to conduct current. It would be pretty hard to use it without getting any on the contacts. Anyway, as I recall there's a gasket on the connector, maybe it can be replaced? Just need to keep moisture out.
Old 06-24-2011, 04:26 PM
the_merv's Avatar
Normal Grease has always worked for me.
As far as the PCM I'd use a toothbrush & some copper solvent from a gun cleaning kit..**** worked perfectly on one I had to clean up. Brushed it, blew it with some air to dry it, then greased the connector and it was good.
Old 06-24-2011, 04:34 PM
Well I just stopped by radio shack and picked up some electronics cleaner. I'll give it a try and post up some updated pictures when I'm finished. Thanks for the advice guys.
Old 06-24-2011, 06:01 PM
Pacer Racer's Avatar
You need to find out how it got corroded in the first place
Are the seals bad?
Is there water leaking down over the PCM?
Old 06-24-2011, 08:05 PM
Seals look good but I'm not sure if they leak. The guy I bought the car from (the original owner) said he always washed the engine off when he cleaned the car. So I'm guessing over the years it has just accumulated water. That and the fact that I live in Washington and it never stops raining here. It's always wet. It cleaned up really well though. I used a small pick to get around the outside of the terminals and the cleaner. It looks nice but I'm going to touch it up again later tonight. I'll post up some pictures when I'm done for a before and after for anyone else who finds themselves in the same positon with a similar problem.
The following users liked this post:
CrystalMarie84 (12-01-2022)
Old 06-25-2011, 10:26 AM
the_merv's Avatar
You're a hero.
Old 06-25-2011, 12:25 PM
Originally Posted by the_merv
You're a hero.
Your sarcasim kills me, lol.
Old 06-25-2011, 12:52 PM
Okay, here are some pictures of what it looks like now after some cleaning. It's about as good as I can get it so it will just have to work. Either way, I guess I can sleep at night now.
Old 06-26-2011, 12:15 AM
the_merv's Avatar
You have low expectations..
Old 07-02-2011, 06:56 AM
fotoboy's Avatar
looks good, how did it work out? What was your process for cleaning?
Old 07-04-2011, 09:41 PM
It worked out good. Just went by radio shack and picked up a small can of electonics cleaner and sprayed down the pcm and the connectors. Let it dry out and put it all back together.
Quick Reply: PCM corossion. How can I clean this up? Pics inside.
