McLeod Scattershield
I'm putting together parts for the T56 swap into a 91 GTA. I bought an LT1 T56 transmission and it comes with the bellhousing, but I like the idea of putting a scattershield in there. I was looking at the McLeod 8760-00 bellhousing. For the people who have this, does it come with the bellhousing bolts? if not, can I re-use the stock ones or does somebody know of an ARP part number for them? Thanks!
If it is an SFI approved bell, it needs class 8 or better bolts. the orig bolts won't meet that. I suspect a bolt set will come with the bell. Also, it sould have an engine plate.
If (but probably when) I do a clutch upgrade and T56 build, I also want to go back with a scattershield. Are both the McLeod's and Quicktime's direct bolt-in for an SS/LS2 or do they require modification?
Thanks for the answers folks, now for the final question, does it need offset dowels to align it with the transmission or do you simply bolt it in like the stock bellhousing and go?
