Small Block & Big Block Chevy Specific - New roller rockers!!! ????
View Full Version : New roller rockers!!! ????
cnukpup
06-24-2011, 07:21 PM
can anyone help me on how to set my 1.7 roller rockers it is a 454 and it is hydraulic i read that all you have to do is tighten the posi lock till the push rod has drag then thighten it 1/4/ to 1/2 more..
is this true and all i have to do?????
please help
poltergeist 02
06-24-2011, 07:51 PM
i always did them while the motor is running. start to tighten them down until the tick goes away then 1/4 to 1/2 turn, tighten poly and all good. i've never had a problem doing it this way. i'm in plainfield so let me know if you can't get it.
cnukpup
06-24-2011, 11:53 PM
i may do that (contact you) do to i have a pacemaker and cant be under the hood while it runs :(
poltergeist 02
06-25-2011, 12:40 AM
thats just an old school trick i learned from a friends dad a while back. there is other ways of setting them without running it while you adjust them.
cambirdracing
06-25-2011, 05:59 AM
This is the way that I have always set them. Tighten the set screw then tighten both the nut and set screw about 1/16 of a turn more. They won't come loose this way. I have never had good luck setting them with the engine not running.
