Help me read a few plugs?
Guys,
I have been chasing a lean condition on the passide of my motor and I pulled 2,4 and 6 plugs tonight. Can you take a look at these and let me know if any look like that cyld. is running lean?
CY 2:
CY 4:
Cy 6:
I know its hard to tell but CY6 is very sooty and looks to be rich where CY2 is pretty clean and the conductor on top is not even black, just a little white ashy color.
I'm going to swap my injectors from bank to bank as well and see if it could be one of them causing the issue.
I haven't pulled CY8 yet as I have to get to it from under the car.
CY 2:
CY 4:
Cy 6:
At WOT the PCM reverts to open loop and disregards the O2 sensors for fuel mixture and all fuel injectors receive the same pulse signal, correct? If so then maybe you have a bad injector like you thought. Have you swapped the injectors to see if the lean condition followed to the other side?
It is often hard to get a good reading on LT1 plugs. This is due to the fact that the throttle body is at the front of the intake the front cylinders get the first look at the air. After running at low engine speeds and especially at idle the plugs will be progressively darker towards the back of the engine.
No one tries to read plugs that have been driven on / ran for any amount of time.
If you're trying to look for a WOT lean condition you will need to put in brand new plugs, do only your burnout and a 1/4 mile WOT run and kill the ignition at the end if the run.
Then you will need a quality otoscope or you will need to cut the threads off the plug.
On a WOT run the porcelain should be CLEAN (white) with a pencil thin fuel ring at the bottom.
If you're talking plugs that are old, as stated before, you're not going to get a good read on them. Idle can darken the plugs and tell you nothing about the rest of the operating range.
bingo...
The only thing that these plugs can tell you is if they are in the right heat range for your motor..
