Trans am blown up
Trans am blown up
So let's start off by saying if anything could go wrong it's been the past few weeks. My wife was driving her trans am home from work and hit a big puddle that was on the road which stalled the car so she coasts off the side if th road gives me a call and tells me what happen so I go there and have her try to turn it over with in 3 seconds of trying to start it I hear a loud pop under the hood I instantly got mad so now I pop the hood looking for something sticking thru my block couldn't see anything. So now I look under the car I see a broken bolt, couple pieces of metal and maybe Like 1/8 of a quart of oil on the ground if that. There wasn't much oil at all on te ground. So needless to say called AAA had them to it to a shop so they can tell me it's trashed. And 4 days ago I just got it back from the shop because the ignition coil and control module were bad and now this. I don't know to much about cars but is something he replaced that could cause the engine to blow or was it te puddle?
These cars are known for big puddles causing the engines to blow up. Water gets sucked into the motor then it just dies. DO NOT try to crank the motor. You can't compress water which causes junk to break take the spark plugs out and turn the motor over by hand and see what you get. Some insurance companies will actually cover this type of thing so try calling them. Good Luck
Agreed with the first two. If you ever run through water and the car stalls, NO NOT try to crank it over in attempt to start it. As mentioned above, water does not compress. Pull the plugs and crank the motor over so there's no compression and any water will blow out the spark plug openings. If there is a puddle of water sitting in a cylinder, it's not a good idea to leave it there. Then leave the plugs out for quite some to help dry any water in the motor. Using a blow gun through the spark plug opening also will help dry up any water.
Sorry to hear of your troubling issue. Good luck.
well if the car is fully covered on insurance, your insurance company may cover hydrolock as some do.. ive read on here a few times of people blowin there blocks from hydro and getting the insurance company to cover it.
Anyone correct me on this if I'm wrong.
Also, do these cars stall because they sense something's wrong?
No they don't at least not to my knowledge they stall if they suck in water like his did because the water gets sucked into the intake and actually stops the rotation of the engine. Then the next time it trys to crank...boom. Btw hydrolocking can and does happen in hard rain. These cars have really bad hood seals and during hard rains water will drip onto the take. If you have a leaky injector o-ring or intake seal water can get in that way. After that the next time you go to start it, well you know what happens.
Ok let me clear some things up for the people wanting to know how the water got in there. First it's 93 trans am the intake that is on there runs down to being in front of the left tire. The car is lowered and the filter sits maybe 5 inches from the ground. Hit a puddle that was about 7 inches deep because the storm drain was backed up and was not draining properly so with the filter 5 inches from the ground in front of the front left tire the first thing that gets nailed with water would be the filter which sucked it up in the intake and so forth.
And in the case of a LS1 I wouldn't say this is a common occurance, but in the right situation if you hit a big enough puddle and enough water gets splashed up and hits the filter and it gets through the filter its going in the engine. A lot of people find it hard to believe this can happen but imagine if you were stomp on a puddle of water the water can splash a few feet. Now imagine a bigger puddle and hitting it with the force of a car, its not hard to imagine how it can reach the filter
