View Full Version : PCM VIN Change
bluemach1
06-26-2011, 03:34 PM
I am doing a engine swap, Ls1 into a porsche 944. This is a california swap so the PCM VIN is very important to how I can deal with emmissions.
I already have had the PCM sent out and tuned for my requirement. However, the unit came back with a VIN from a 2000 Camaro. As I am in California, I would prefer this to have a VIN from a 2002 F-Body. This is so I can get rid of the EGR stuff mostly.
The question is this; can any tuner that I send this to reprogram the VIN?
minytrker
06-26-2011, 05:29 PM
A tuner with EFI Live can change the VIN or someone with HP Tuners can tune the whole tune to a 2002.
edcmat-l1
06-26-2011, 06:08 PM
Anyone should be able to change it. Those with multiple types of software can put in any vin you want basically. ;)
bluemach1
06-26-2011, 07:35 PM
Great. So if i pick up a second hand HP Tuners with credits for at least one car, I can do this myself?
minytrker
06-26-2011, 09:58 PM
I only use HPT and EFI but I have run into problems when I changed the VIN with EFI and it didnt match the OS and I would get a VIN/OS mis match or something like that with HPT. I dont think you can change the VIN to a 2002 with a 2002 OS with HPT but I could be wrong.
roughneck427
06-27-2011, 12:05 AM
Where you at in CA?? If your near fresno i can change it i have Tunercats and dont have to license the pcm to help you out.
macca_779
06-27-2011, 05:44 AM
Hptuners uses vin numbers for licensing. Because of that it's quit restrictive in allowing vin changes. EFI live doesn't use VIN's just the serial number of the PCM itself. Because of this you can change it to what ever you like. So if looking for tuning software I'd give hptuners a miss and go for EFI.
bluemach1
06-27-2011, 09:59 AM
Roughneck427 -
I am in the Sacramento area.
