Switching to a 350 turbo
Old 06-26-2011, 04:07 PM
6.0ltrS10's Avatar
Default Switching to a 350 turbo
We are switching to a 350 Turbo with transbrake. Does the PCM need to see the speed sensor input? or can i just wire tie all the 4l60e wiring up and out of the way and have the trans functions removed from the PCM.
Thanks
Old 06-26-2011, 04:13 PM
dtsti's Avatar
I dont believe it needs to be hooked up. I pulled out my th350 out of my car and there were no wires hooked up to it.
Old 06-26-2011, 04:32 PM
MontecarloDrag's Avatar
It will work good with no other changes than disablig DTC's
However, there are better ways to do it, like a segment swap and installing a Vss
Old 06-26-2011, 04:40 PM
6.0ltrS10's Avatar
Are you taking DTC's for the transmission? What do you mean segment swap? If I put a vss in does it need to be the 40 pulse/rev?
Old 06-26-2011, 05:03 PM
Yes, if the 4L60E harness is unplugged the PCM will give several transmission DTC's. You only need to disable them and it will work good. I did it with a few cars and no problems after 3 years of daily driving.
With a segment swap you convert an automatic tune to a manual one.
The Vss signal is to let the PCM know the car is moving so it uses the correct timing tables, it doesn't need to be acurate.
Old 06-26-2011, 06:35 PM
6.0ltrS10's Avatar
That makes sense now.
Thanks
Old 06-26-2011, 08:27 PM
LS1MCSS's Avatar
Some people that have done swaps have had trouble with the engine dying, when coming to a stop, without a VSS. Some people have had good luck without one. It seems to be hit and miss as to whether or not the engine will try to die when you come to a stop. If it tries to die, just get an aftermarket vss that will screw onto the th350 tranny. Several different companies have them.
Old 06-29-2011, 12:29 AM
minytrker's Avatar
I have done a tone of th350, th400, and glide swaps over the years. Its better to flash the pcm over to a 6 speed, I have had some have torque management issues when I left the 4l60e tune there and some work fine. On my own car I have had several motors and went from 4l60e, th400 to a glide and left the 4l60e tune in there and never had problems until my last motor and the glide. I just swapped the current tune over to a 6 speed and the torque management issues went away.
Quick Reply: Switching to a 350 turbo
