Paint & Body Work - Bumper repair and paint.
cbr600rx7
06-26-2011, 05:31 PM
I have a 3-4 inch cut in the front bumper and just kind of looking around at my options. A new front cost about 200-250 bucks and then would need to be painted. I also have some paint fade on the hood, that needs to get touched up. I dont want to take the car to a body shop unless i have too so i was considering trying to use M3 bond on the bumper and trying to buffer the hell out of the hood.
Posting a few pics to give you a idea what i am working with.
http://i205.photobucket.com/albums/bb36/cbr600rx7/100_1407.jpg
http://i205.photobucket.com/albums/bb36/cbr600rx7/100_1408.jpg
99427camaro
06-26-2011, 06:41 PM
the hood has been buffed to far so buffing will not make it any better with the bumper there are steps you have to take to get a bumper repair to take if you fill it with the 3m stuff with out prepping it right it will fall right off
i would go to a good local body shop, that is known for doing good repairs not just parts changing and get them to throw you a cash price, at my shop i would take 500-600 to fix the bumper and hood but if you take the parts off they may charge you less
cbr600rx7
06-28-2011, 06:01 PM
Thats not too bad. I replaced the bumper on my 2000 WS6 for about 200 and paint was another 200. I think repainting my hood was about 250-300 if i remember right. I kind of wanted to do as much of the prep work as i could myself.
I am assuming by prep work you mean removing the paint around the area of application, then making sure there is no oil or any contaminants on the surface that you are trying to bond too.
99427camaro
07-02-2011, 10:57 AM
also snading out the bad spots on the hood with 320 or 400 than takeing a red scuff pad or 500 and sanding all of the gloss off
If the clear in the area on the hood has not broke down you can sand it w/ 500 and the rest of the hood with 1000 and paint it. Thats in a perfect world. Typically the front of the hood will have some rock chips that will have to be da'd out and primed then blocked and finish sanded w/ 500 for paint. A little more work but worth doing right if you paint the hood.
The bumper needs to be taken off to fix and paint right. There are several steps to do a quality plastic repair and most of the products are only available at a P&B supply store.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
