want to run a 200 shot..can i do it on pump gas
Old 06-26-2011, 06:27 PM
WALK NASTY984's Avatar
Default want to run a 200 shot..can i do it on pump gas
2002 trans am...Torquer v.3 cam full bolt ons and a 100 wet shot would like to bump up to a 200 shot just dont know if i can run that big of a shot on just regular premium gas? any help be appreciated!!!
Old 06-26-2011, 06:37 PM
ryarbrough's Avatar
You can, but I wouldn't risk it. Why not throw some good gas in the tank or run a stand alone?
Old 06-26-2011, 06:54 PM
87silverbullet's Avatar
I did it but wouldn't recommend it. You have to make sure you have enough timing pulled.
Save yourself the risk and get a standalone unit with race gas in it.
Old 06-26-2011, 08:01 PM
please excuse my ignorance im noob to the hobby...but what exactly is a stand alone system and where can you actually buy racing fuel at?
Old 06-26-2011, 08:05 PM
ryarbrough's Avatar
A stand alone fuel system is a separate fuel tank and pump that you feed the fuel side of your nitrous system with. It allows you to run good gas as a supplement to what is in the tank. You can pick up race gas at any local speed shop, or in some instances, the local sonoco. Most racetracks sell it too.
Old 06-26-2011, 08:07 PM
Canbarelygo's Avatar
a stand alone is a seperate small fuel tank with a dedicated pump and what not that supplies the fuel strictly for fuel side of the nitrous which takes stress off your intank pump and fuel rails and it takes care of worryin about fuel pressure stayin consistent in the rails and what not.
as far as buying race fuel im not sure about you we have a few bike stores around here where i live such as a yamaha and honda bike shops that can get race fuel. also big fuel distributers such as red rock that may be based somewhere in your area may carry some
Old 06-26-2011, 08:09 PM
who sells a good stand alone system?
Old 06-26-2011, 08:11 PM
ryarbrough's Avatar
Look at our sponsor list. Nitrous Outlet, HSW, NX and others all have nice setups.
-M-
-M-'s Avatar
Most race tracks sell race fuel to the public, although its not cheap. if your looking into barrels of it, contact the track and ask if they sell by the barrel or where you can purchase it...
Race fuel isnt for a stock motor, though...
Old 06-26-2011, 08:13 PM
ryarbrough's Avatar
There's nothing wrong with using race fuel with a stock engine. If you can consider an engine with a. 078 pill "stock"
Old 06-26-2011, 08:20 PM
so what needs to be done to my motor to be able to safely run racing fuel...again please excuse my ignorance
Old 06-26-2011, 08:23 PM
ryarbrough's Avatar
Nothing if its just a stand alone. You may foul O2 sensors mire quickly if you use it as a primary fuel though.
Old 06-26-2011, 08:25 PM
ok thanks for all the help guys
Old 06-26-2011, 08:31 PM
yea i dont see racing fuel being a problem to the o2 sensors in just the nitrous side of the motor but i wouldnt suggest it in the primary system for something your gonna drive all the time because its pricey for one and for 2 as stated above you have the chance of makin the o2 sensors go bad
Old 06-26-2011, 10:19 PM
Nitro Dave's Nitrous Outlet's Avatar
We are the ones that invented the all in one stand alone fuel systems. We have lots of different versions that fit in alot of different applications. For the F-body we have three specificly designed systems that easily bolt into your car.
Here is a link to them on our website.
http://www.nitrousoutlet.com/catalog...=24&section=73
Old 06-28-2011, 11:41 AM
TA1364's Avatar
Why would you need a barrel of race gas for a stand alone? lol
Old 06-28-2011, 11:45 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Cheaper to buy by the barrel. Also you can fill up before you leave and its one less thing to do at the track.
Old 06-28-2011, 12:32 PM
Gregory's Avatar
Could E85 be used as a 93-octane replacement? E85 octane is about 105-octane.
Old 06-28-2011, 01:27 PM
Guest
Posts: n/a
It can if you are jetted and tuned correctly. E85 is great stuff when done right.
Quick Reply: want to run a 200 shot..can i do it on pump gas
