low timing
Old 06-27-2011, 05:35 PM
IamSam's Avatar
Default low timing
I just replaced my 2 knock sensors in my 01 lq4. The check engine light went away so all is well i suppose. I noticed that my timing at cruise is around 38 degrees and at wot its about 16-18 degrees depending on rpm. Is this right or is somthing wrong? Stock engine and this is according to my scan tool. Thanks
Old 06-27-2011, 06:49 PM
trance565's Avatar
Seems a bit low at wot, 38 in cruise cells is acceptable depending on the setup
