loud squeeks on hot days
If the outdoor temp gets over 85 degrees my car squeaks obnoxiously. Every bump is this loud terrible noise. As the out door temp cools the noise goes away. Is it rubber bushings? Any idea on a fix so I dont have to be embarassed?
Mine were the front and rear sway bar bushings, on a hot day when the car ran for a while they would squeak bad. Hitting them with WD40 and then white lithium grease was only a temporary fix. Once I replaced them, and the endlinks, with poly ones (energy suspension) the noise went away. I got greasable ones on the rear, unfortunatly I couldn't find greasables for the front.
Does that noise come from the front driver's side and sound like a 500lb couple having sex on an old worn out spring mattress? Seriously, no pun intented. I have the same noise and if it really is the sway bar bushings I am going to have them replaced ASAP. Did you alread replace yours and did the noise go away?
