what else do i need with the ls6 heads.
Old 06-27-2011, 11:10 PM
subbie racer's Avatar
Default what else do i need with the ls6 heads.
i know i need the ls6 oil pump and i got an ls2 timing chain (i got my car tuned today and the guy who tuned it had a set of ls6 heads so i brought them) he said the ls2 timing chain is better to use since its stronger, and i also wanna upgrade the rocker arms but not sure what to get, i was looking at these ( http://www.summitracing.com/parts/SUM-G6980/ ) and can i reuse my ls1 springs? they didnt come with them and also do i need to upgrade lifters?
http://www.youtube.com/user/notsodar.../0/iAplh7nhyA0
my tuning i got today 367hp 366 torque
Old 06-27-2011, 11:38 PM
99screamindemon's Avatar
i would just upgrade to the comp trunion stock rockers but that is just me and i would not use the ls1 springs but i guess it depends what you do for a cam?
Old 06-27-2011, 11:54 PM
it has a COMP cam, but idk the specs until i pull it out
Old 06-28-2011, 12:14 AM
RedRallyeZ's Avatar
get new springs and dont worry too much about the rockers right now. any sort of aftermarket cam is going to be much better served with stronger springs, also a way to protect that investment. check TSP's spring sets. Ive have been running their old design dual spring and titanium retainer kit for much longer than people said i should have been able to. some sort of aftermarket spring should be considered mandatory with a cam.
As for lifters, its a good idea, but not a necessity. The thing about them is that your old ones have some miles on them, and you have to remove heads to get them in and out. so while the heads are off, its probably a good idea. LS7 lifters are fairly cheap. once again, call TSP.
Old 06-28-2011, 07:47 AM
BrntWS6's Avatar
I only have 18K miles on my car and I changed to LS7 lifters and LS2 lifter treys since the heads were off. I'm sure I would have been fine but removing the heads wasn't something I wanted to do again anytime soon.
I stuck with my stock rockers but would have gone Yella Terra if I upgraded.
Old 06-28-2011, 12:31 PM
alright sounds good, i have a new question about the oil pump, do i have to drop the motor to do all this? the oil pan is pretty close to the cross-member
Old 06-28-2011, 02:39 PM
RedRallyeZ's Avatar
no, you can just loosen the pan and have enough play. ls1howto.com has a complete walkthrough
Old 06-28-2011, 11:29 PM
what about changing the oil pan gasket bit sure mines leaking
Old 06-29-2011, 12:45 AM
RedRallyeZ's Avatar
in the sticky about how to change rod bolts with the engine in the car, he gives a good walkthrough on how to drop the pan with the engine in the car
Old 06-29-2011, 01:05 AM
thanks man
Old 06-29-2011, 10:30 AM
garygnu's Avatar
how many miles on the motor?get new springs,comp 918,pac 1218 ,etc.do a trunnion bearing upgrade.what push rods will you be using?
Old 06-30-2011, 07:26 AM
it has 151k supposedly it was freshen up before, im not sure the kinda push rods i need
need to get new head bolts, might go with arp, i wanna upgrade the connecting rod bolts (heard that the rod bolts are the cause of spun bearings) and bearings and im wondering if i can change out the crank bearings without having to drop the motor out
Old 06-30-2011, 11:59 AM
and do i need shorter push rods since the heads were shaved 25 thousands, i got the heads from Jeremy Formato (from fasterproms.net) who just did my tuning, he also gave me the chain and valve cover and told me to shave the heads 25 thousands
Old 07-01-2011, 12:19 PM
anyone?
Old 07-01-2011, 12:51 PM
BrntWS6's Avatar
Shorter than what? I'm running LS7 lifters, my heads are milled 20 thousands and I'm using 7.35 pushrods. I'd buy a PR checker for $20 to be sure though.
Old 07-01-2011, 10:39 PM
short than my stock pushrods if i can use my stock ones than great, less money to spend
Old 07-02-2011, 08:08 AM
BrntWS6's Avatar
You have to run hardened pushrods anyway or you'll bend the stock one's.
Old 07-02-2011, 10:02 AM
vettenuts's Avatar
You should measure to make sure of the length. If these are LS6 heads with the light valves, don't go crazy on valve spring stiffness. As suggested earlier, PAC 1218's would be a good choice. I would stick with stock rockers but upgrade the trunnion. Other option if the car has a lot of miles is new stock rockers, GM corrected the bearing issue several years ago.
Old 07-02-2011, 12:10 PM
00pooterSS's Avatar
Also if they are Z06 heads, not just 243 heads but actual Z06 heads with lightweight valves the valves are longer than normal so you will need to get the right size pushrod's for those vavles.
They are .030" longer
Old 07-02-2011, 10:20 PM
alright thanks guys, i seen the hardened ones on hawks and im pretty sure these are real z06 heads, i seen the car that it came off of, dont think Jeremy would lie and plus he has great feedback on his site
