will 98-99' headers fit on 01'
Old 06-27-2011, 11:26 PM
whiteNrude01's Avatar
Default will 98-99' headers fit on 01'
I bought some used edelbrock shorties #66722 for dirt cheap, didnt take into consideration that these are 98-99' LS1 Headers, is there ANY way to make these fit onto my 2001'?
Old 06-27-2011, 11:55 PM
TankTheTurtle's Avatar
Shouldn't be much difference. Do they come with the fixtures for EGR and AIR?
Old 06-28-2011, 12:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
they will fit, its just the provisions like mentioned above that will be different. You will probably need block off plates.
Old 06-28-2011, 01:06 AM
Starz T/A 17's Avatar
Yes they will fit the car, but 1. You will need to block the EGR and possible the AIR fittings since your car does not have an EGR valve. I don't know if the hookups for the AIR will fit because the manifolds were redesigned in 2000.
Also because they are shorty headers I am pretty sure you would need a new Y pipe/cats. Since the exhaust changed design in 2000. Which is why there are 2 different y pipes available for stock cars. 98-99 and 00-02
http://www.thunderracing.com/shop-by...haust/Y-pipes/
Your best bet would be to try and find someone who switched to long tubes and pick up there 98-99 Y pipe and cats since most people will sell them pretty cheap
Old 06-28-2011, 10:25 AM
Alright thanks for the help guys
