How do you remove 02' TA Taillamp housing?
Old 06-27-2011, 11:49 PM
jthunderz28's Avatar
Question How do you remove 02' TA Taillamp housing?
Im trying to replace the outer bulb in my tail lamp and I cannot pull the housing back far enough to get in there and replace it. I removed the 4 wingnuts. I dont wan't to break the thing.
Shouldn't that be enough to loosen up the housing to get in there.
How do you do this? I checked the manual and it looks like the entire housing should come off after removing the wingnuts but that is not happening.
Help/advice is much appreciated
Old 06-27-2011, 11:51 PM
APG12's Avatar
Just pull up or give it a little wiggle. Sometimes the threads on the bolts catch the lip of the body.
Old 06-28-2011, 12:12 AM
i tried pulling and wiggling in every direction possible. It almost seems as if there is something on the outer end where I'm trying to get to that just won't allow me to pull of the housing.
So annoying. Anyone else have issues when trying to do this?
Old 06-29-2011, 01:26 PM
bump, anyone out there change theirs recently??
Help! i hate driving around with bulbs blown out. I really dont want to shatter it trying to pull it off so I can get in there to swap the bulb.
Old 06-29-2011, 03:54 PM
Swiat34's Avatar
You said FOUR wing nuts? There's a 5th one way in there.
Old 07-03-2011, 09:19 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Correct! The fifth one is almost to the outer edge of the tail light housing.
Don't tug on it too much...they can break off.
Old 07-06-2011, 12:09 AM
Thank you. That give me back my sanity over taking care of something so simple. It's weird the manual says 4 wing nuts.
Old 06-23-2012, 09:03 PM
mezzyshreder's Avatar
I did the same thing many years ago lol
Quick Reply: How do you remove 02' TA Taillamp housing?
