what the hell is that!
Old 06-28-2011, 05:10 PM
Tolley's94z28's Avatar
Default what the hell is that!
okay so i pulled my motor a few days ago, she turned 100k so i thought i would freshen it up and what not, and found this little hole between the intake and the block on the backside of the engine, what is it, and why is it there?
Attached Thumbnails what the hell is that!-photo_d87f58fd-ed91-2063-ade8-262dbe39e70c.jpg
Old 06-28-2011, 06:11 PM
jay7199's Avatar
looks to me like someone drilled a hole in it.. i have no idea why..
Old 06-28-2011, 07:05 PM
jay7199's Avatar
Btw is the hole going into the head at all? hard to tell from the picture.
Old 06-28-2011, 07:34 PM
transbird95's Avatar
That is weird, can you get a better pic at all?
Old 06-28-2011, 07:39 PM
fex77k's Avatar
Get the oil off and then get us a real picture. I would be for the oil sender, but I can't see a damn thing in that picture. Some of the 94's did have their sender up top and others on the bottom above the filter.
Old 06-28-2011, 07:41 PM
lt1-xjs's Avatar
Looks like the normal intake leak to me.
Old 06-28-2011, 07:54 PM
Village Troll
SS RRR's Avatar
You buy this car used? I am thinking it is either an attempt or a leftover from a hidden direct port system.
Old 06-28-2011, 07:57 PM
fex77k's Avatar
I can't see a damn thing in that picture. Some of the 94's did have their sender up top and others on the bottom above the filter. That hole doesn't look to be in the right place for the sender thou, it does look to be the source of your massive oil leak.
Old 06-28-2011, 08:15 PM
Big Al's Avatar
My guess is the cross drilled hole that connects the top oil port for the pressure sensor to the oil passage. It has a plug in it.
Al
Old 06-28-2011, 09:00 PM
nitrous2fast's Avatar
Custom PCV hole....
Old 06-28-2011, 09:03 PM
henry172's Avatar
I don't think it was for the oil pressure sensor it is way to close too the head; my oil sensor is closer to the middle of the intake.
Old 06-28-2011, 09:25 PM
97Z28SS's Avatar
It's just a normal oil passage which should have either a soft plug or a pipe plug in it just make sure when you get your block back from the machine shop that either a pipe or soft plug is put back in otherwise upon startup all of the oil will leak from your engine and kill it.
Old 06-28-2011, 09:28 PM
jlpz's Avatar
Looks like the oil sending unit...but the pic needs to be a bit better...
Old 06-28-2011, 09:31 PM
shbox's Avatar
It's an oil gallery hole that has a plug in it. Every LT1 block has it.
Old 06-29-2011, 09:56 AM
Village Troll
SS RRR's Avatar
That's an oil plug? Maybe my eyes deceiveth me, but that looks like a hole drilled into the block? It's under the head as well which looks to be in the wrong location for an oil galley plug...
It would explain the massive amount of sludge all over creation as well...
Old 06-29-2011, 10:11 AM
quik95lt1's Avatar
agreed thats a cleanly bored hole not threaded.........i have no idea why someone would do that???
Old 06-29-2011, 10:20 AM
Village Troll
SS RRR's Avatar
Like I said earlier... I think it may have been something left over from a hidden direct port system under the manifold.
Old 06-29-2011, 10:24 AM
quik95lt1's Avatar
yea i agree thats about all i can think of unless somebody had a really bad idea for a crank case ventilation point lol........id be curious to see if there are any holes in the bototm of the intake manifold......that will tell it
Old 06-29-2011, 10:28 AM
sweetbmxrider's Avatar
Yeah that's what it looks like to me. Definitely not for some hidden nitrous lulz.
Old 06-29-2011, 10:30 AM
93M6Formula's Avatar
Yeah that is in no way a factory deal there, that's odd.
Quick Reply: what the hell is that!
